AFR 225 Info...
Old 07-12-2004, 12:57 PM
  #41
Viper's Avatar
tsp - good price right now
Old 09-13-2004, 12:15 AM
  #42
JimMueller's Avatar
Originally Posted by Tony Mamo @ AFR
With that said, my best guess is that we will START shipping 225 product sometime the latter part of August....It could happen sooner, but I wouldn't be as comfortable quoting that. If you have been waiting and can't wait a moment longer, we certainly understand, but I'm confident the 225's will up the performance "ante" and will be very much worth the wait.
Any update on the 225 availability?
Old 09-13-2004, 12:25 AM
  #43
racer7088's Avatar
Arrow
Originally Posted by J-Rod
Cool..
Don't sweat your static compression. Look at your DCR... Thats going to tell you whethere or not it will ping.
Think about it this way. If you have a small cam with no overalap and X compression, it going to be different than the same compression in a big cam motor with lots of overlap bleeding off cylinder pressure.
Jrod,
Overlap doesn't bleed off compression.
Old 09-13-2004, 12:36 AM
  #44
racer7088's Avatar
Thumbs up
Originally Posted by HumpinSS
A big *** paper weight that flow like mad and makes absolutely no power
Humpin,
AFR has great products that I have used and am also almost always happy with but that doesn't mean they are the only ones that can port heads. 90 per cent of the head porters out there are not exactly great but there are some that are and understand what is going on. We have stock ported LSx castings capable of right at 800 hp. Saying that I am really looking forward to seeing the 225s and in fact even the 205s if we can keep them on the shelf again. The only ones we've recieved were sold IMMEDIATELY!
The Ford heads are also great from AFR. We just had a set make almost 670 at 7300 rpm on a 418 at SAM and we'll do some tuning this next week to make more and bring it down in rpm a little too! Some of the Ford head porters and gurus on "another" site were giving it 550 hp and 6500 rpm! These heads flowed within 1 percent of what AFR said they would as most of them have on our bench.
Quick Reply: AFR 225 Info...
