5.3 leak
Old Jul 18, 2018 | 05:21 PM
Stoplightbandit's Avatar
Default 5.3 leak
so I have a 5.3 in a buddies truck that started spitting oil out of the spark plug. Not a little leak. I mean it was shooting out everywhere. The plug was tight in there so I was kind of amazed. What could cause that?
Old Jul 18, 2018 | 05:27 PM
The spark plug is not near any oil. UNLESS the valve cover is leaking oil down to the plug, and it has "lubed " the plug loose, causing compressed gases to leak and spit oil from around it.
Old Jul 18, 2018 | 05:28 PM
RB04Av's Avatar
Or of course, if it has some kind of a piston / ring issue, and that's how oil is getting into the cyl.
Old Jul 18, 2018 | 05:37 PM
I hear you both. But it’s really shooting out about two to three feet my first thought was a valve seal but that just doesn’t seem likely to me. Should I just pull the head and take a look? I’ve never seen anything like it before.
Old Jul 18, 2018 | 06:22 PM
Kawabuggy's Avatar
Can you post a video of this? I'm sure we would ALL love to see exactly what is happening..
Old Jul 19, 2018 | 06:00 AM
Too late now. Already pulled the intake and it looks like a tar pit in there
Old Jul 21, 2018 | 05:09 AM
07NBSChevy's Avatar
Only thing I can think of, if it is truly coming out of the area around the spark plug is, somehow the cylinder is filling with oil, and then somehow pushing it out the spark plug/hole.
Old Jul 25, 2018 | 07:38 AM
Ls7colorado's Avatar
if there was that much oil in the cylinder it would hydro lock and bend a rod, pushrod, or something.
I agree with the first comment, its probably leaking valve cover gaskets and a loose spark plug.
