LS6 block is dead. Can a LQ9 be swapped?
(I will be getting different pistons and bored to match.)
https://dartonsleeves.com/mid_02.html
LS2, LQ9, LM7...it doeent matter, pretty much any of the Gen 3 or 4 engines all swap in with minor work and sometimes some adapter harnesse.
If you want complete plug and play and to not convert anything you'll need a gen 3 motor. That's gonna be an LS1 or LS6 if you want to stick with an aluminum motor. But converting isn't bad at all, and you're likely to find an LS2 for the same price as an LS1 or 6 and I would rather have the LS2 for the 4" bore.
Gen 3 motors have the cam sensor in the back, gen 4 it's in the front timing cover and reads the timing gear instead of reading off the back of the cam. Gen 3 knock sensors are in the valley cover under the intake and gen 4 they are on the sides of the block. It's not too bad converting if you find a gen 4 block for a good deal.
Plug and play conversion box for putting a gen 4 motor where a gen 3 used to be.
https://www.lingenfelter.com/product/L460065397.html
NOT saying this is the case as I have NO IDEA but....... id like to see the cylinder walls if I was you and what was the reason for a rebuild?
I've had low oil pressure for a while, added a lingenfelter oil pump but didn't help all that much. Engine is in a sand car so I'm sure it eats sand here and there.
End issue was a lost rod bearing
