HELP!!! Machine Shop Northern VA.
Thanks in advance guys
Derek
Jeff at Gunther’s Machine in Walkersville MD is also a decent shop too. Have had a few issues with him with stock rebuilds on the older Gen 3 motors where he references the chamfer on the rod for the orientation (the way just about everything else in the world is) vs point the flat of the rod to the front of the motor. Other than that small issue he has the ability to sonic check blocks etc. His work is pretty good as well. He builds motors for several motor sports teams so he is also super busy.
If your doing a full on build with aftermarket rods etc I wouldn’t be scared of Jeff or Dave. If your willing to go alittle further north there are a ton of machine shops that specialize in building sprint car motors (south central PA is one of the biggest hotbeds for sprint car racing in the country). Either way your gonna have to wait.
There is a good machine shop in Falls Church that I have used a few times. Next to the Volvo dealer. I would have to look up the name, but IDK if they actually build engines. the owner/operator is a good guy and he has loads of cool stuff in there with blocks getting setup for awesomeness.
C & C Auto Performance in Manassas would do it all, but IDK how LS savvy they are. Not that a stockish LS is hard to build at all.
As for exhaust I have heard these guys are the best Roberts Custom Exhaust in Stafford (full custom SS level ish) But if it is easy then Hi-Flo Custom Exhaust in Manassas is fine and I have used them before w/o issues.
awesome. Thanks. I’ll look them up. I knew o could count on you guys
