Lifter preload delema
Old Jul 31, 2018 | 10:20 AM
TTG's Avatar
TTG
That would put me at about .062.
Old Jul 31, 2018 | 02:11 PM
Jenson's Avatar
Yes they fit. Your math is confusing me. .005" shorter push rod nets you .012" less preload?
Old Jul 31, 2018 | 02:17 PM
Jenson's Avatar
Would ya just look at it;
https://ls1tech.com/forums/generatio...l#post17388244
.200 worth of travel.
Old Aug 1, 2018 | 06:10 AM
Jenson's Avatar
I measured mine last night as well, also in the .200" travel range
Old Aug 1, 2018 | 06:43 AM
vettenuts's Avatar
Huh? 0..005" shorter pushrod should net 0.005" shorter preload on the lifter.
Old Aug 1, 2018 | 07:10 AM
TTG's Avatar
TTG
Yeah, I screwed up somewhere. I have exceeded my capacity for number crunching for an entire year. Jarheads dont usially think this much, lol!
9.125 turns x .050 + 6.8" base length = 7.25625, -7.325 = .06875. So basically it would be .069 preload.
Old Aug 1, 2018 | 07:37 AM
01ssreda4's Avatar
I'm running about 60/75 preload now but have seen as high as 120 with no issue.
Old Aug 1, 2018 | 08:12 AM
cam's Avatar
cam
I like .0080 after running as low as 50, and as high as 120. 80 seems best, been very high in RPM, no tick. 120 winked pistons, 50 worked great but ticked like crazy.
Old Aug 1, 2018 | 08:44 AM
kinglt-1's Avatar
I would try to get around .080 preload with LS7 lifters.
Old Aug 1, 2018 | 09:08 AM
TTG's Avatar
TTG
The next step up from 7.325 is 7.35. That would add .025 to .069, which would put it at .094. I think thats too high. I would rather have it a little low than a little high i think.
Old Aug 1, 2018 | 09:17 AM
Jenson's Avatar
At least your doing better at math today!
Old Aug 1, 2018 | 09:19 AM
  #32
kinglt-1's Avatar
That is not too high at all. LS7 lifters like a lot of preload coming around .200 travel...it's a spongy lifter. Most shoot for .070-.090. 7.325 will put you on the light end of acceptable. Try it and see how it ends up.
Old Aug 1, 2018 | 09:36 AM
  #33
TTG's Avatar
TTG
ha ha! Yes, I am fresh off the coffee pot!
Old Aug 1, 2018 | 09:43 AM
  #34
TTG's Avatar
TTG
I have been told it has .160, then .180, now .200! Which is the real number??
Old Aug 1, 2018 | 10:17 AM
  #35
TTG's Avatar
TTG
Just got off the phone with comp. The ls7 lifters have between .160 and .166 cup travel. 7.300 would put me at .044 preload. 7.325 - .069, and 7.35 - .094. With a target of half or a little under half, he recomends definately going with the .069 preload. Lighter could cause valve train separation, and higher could cause lifter failure or lower rpm. So its settled! Thanks all for the help, and catching my fuzzy math! I will update the thread when i get it going and let everyone know how it works out.
Old Aug 1, 2018 | 10:45 AM
  #36
kinglt-1's Avatar
Comp is the last place I would call for information.One thing you are not accounting for is heat expansion which will cause about a .012 loss in preload. So you your .069 will be .057 when up to temp. This topic has been discussed a thousand times over the years here. I just googled "LS7 lifter plunger travel" and came up with pages of results. Here is one thread with info.
https://ls1tech.com/forums/generatio...066-091-a.html
another good read here.
https://gwatneyperformance.com/lifte...ont-hurt-will/
Old Aug 1, 2018 | 02:13 PM
  #37
BlwnLs1GTO's Avatar
.080 is ALWAYS my target preload on LS7 lifters. I've never had an engine tick or sound like a sewing machine at this preload. Trust me, that sound is annoying.
Also,
What about your different sized banks? I may have read your original post wrong, you're not running two different head gaskets are you? Don't
You should be just fine running a 11/32" PR with a preload near or at .080" IMO. Again, IMO. Also, it's always a good idea to measure each and all 16 valves for the proper preload.
I've found many rebuilt engines with severe differences in between valves. Especially if the heads/valves have been worked on. It only takes one value with minimal preload to make noise.
Good Luck with your build!
Old Aug 1, 2018 | 08:16 PM
  #38
Floorman279's Avatar
i have seen the expansion discussed......i was thinking it still wouldn't change anything because it all is getting hot and expanding. but then i started thinking, an aluminum block will be a little warmer than the heads so the block may expand a little more than the heads. thus tightening up preload
Old Aug 1, 2018 | 10:07 PM
  #39
A block expanding would LOOSEN preload, not tighten it. The block/heads expand more than the pushrods, thereby increasing distance between cam and rocker arm.
Old Aug 2, 2018 | 10:06 AM
  #40
kinglt-1's Avatar
If the aluminum block and heads expand, that means growth, which is similar to making the push rod shorter since it didn't change with heat... thus reducing preload. You increase push rod length to add preload not the other way around.
