Need Building suggestions LS1
Old Aug 23, 2018 | 03:29 PM
sandman54's Avatar
Default Need Building suggestions LS1
Heres what I want to do first....exhaust(headers,ypipe,catback) converter, tune. Then im gonna do heads, cam, and NOS and retune... what converter will work? what heads and cam should I go with?
Old Aug 23, 2018 | 03:40 PM
Tuskyz28's Avatar
How deep is your pockets?
Old Aug 23, 2018 | 03:44 PM
HCI2000SS's Avatar
More details...
Old Aug 23, 2018 | 04:00 PM
sandman54's Avatar
Originally Posted by HCI2000SS
More details...
Well I have a 01 SS that is all stock. I just wanna know what the best things to do first is? Im not gonna boost it im gonna spray it eventually.. I know its gonna need exhaust and people tell me to put a converter in it(I don't know what size) and then I was gonna get it tuned. Later down the road im gonna put heads,cam, and nitrous( I already have the nitrous kit) Ive been out of the loop for about 10-15 years so I don't know what the best thing to do first is. It does have drag radials on it now but motor is all stock.
Old Aug 23, 2018 | 04:19 PM
HCI2000SS's Avatar
Well since you are going from bone stock to totally modified, I'd call some of the vendors on here. They can get into great detail over the phone, whereas on here it's more difficult. From exhaust, to heads, to cams, to intakes, to nitrous, to other bolt ons, to valvetrain, to tuning, etc, etc...there are dozens possibilities within each of these categories. And let's not forget suspension and rear support as well. It's all in how much you wanna spend
Old Aug 23, 2018 | 04:23 PM
If you want a one-stop shop for good info, quality parts, and VERY fair prices, gat a hold of WS6store, a vendor/sponsor here.
Old Aug 23, 2018 | 04:24 PM
FCar2000TA's Avatar
Veteran: Air Force
Transmission and rearend should be the first upgrades. Dana 60 is probably the strongest rearend option, Ford 9" is 2nd, and GM 12bolt is last. Don't try to upgrade the stock 10 bolt. If you throw more torque at a 10 bolt, you will have a rearend with a lot of pieces in it pretty soon. And, blowing your rearend can cause transmission damage too. Headers, cam, and 90mm intake blew up my 10bolt, which took out my transmissino too.
Old Aug 23, 2018 | 04:51 PM
z-maro's Avatar
You also have a manual, autos are a lot easier on the rears.
For the OP, 1-7/8" headers, full exhaust, air lid, and a ram air kit is a good place to start. If I could start from scratch I would have gone with a 3.5" or 4" outlet on the Y-pipe, or TD's out the back. Cam choice is dependent on your goals with the car an how much nitrous you plan to use. Heads are very budget dependent, best you can afford and I would say the same for the intake.
Old Aug 24, 2018 | 03:35 PM
00pooterSS's Avatar
With an auto a 10 bolt would live behind that just fine.
Old Aug 24, 2018 | 05:15 PM
tech@WS6store's Avatar
LS1Tech Premium Sponsor
Thanks Atsma
We do have every part youll need and the tech support for it also!!
Email me with your budget (most important) and goals (tied for most important) and current mods and we will get you set up!
Thanks
Ws6store
Rpmspeedtech@gmail.com
