Hard turning of 408 stroker
Also when a starter just clicks, either you have a bad connection or a bad starter. The bad connection is usually at the battery, pull the terminals and clean them with water and a metal bristle brush. Or it's just clicking because the engine is seized
A V8 short block, freshly built, with typical tension rings (not "low") and good fresh bores, should take around 30 - 35.
As said above, with just the crank in, it should spin easily by hand; you should be able to grab the snout, spin it with a flick of the wrist, and it should keep spinning for a half-turn or more before it stops. Then, as you add pistons it should get progressively harder for each one, by about the same amount each time. With the first few pistons it should spin easily as the pistons go through TDC and BDC but as you add more it should get more uniform all the way round as you turn it. Adding the cam shouldn't be noticeable at all. Putting on the heads should make no difference whatsoever. Putting in the rest of the valve train should add a few ft-lbs, maybe 5 - 10. So all the way put together it might take 40 - 50 ft-lbs on the crank. Accessories might add a few more.
Does it turn easier with the belt off?
