Looking for formula for piston ring gap
Old Sep 20, 2018 | 06:37 AM
Soflown's Avatar
Default Looking for formula for piston ring gap
Looking to see is anyone knows the formula for setting up piston ring gaps. I am currently doing my 2002 6.0L turbo build and have heard I need a specific gap set on my first and second ring. Any help would be appreciated.
Old Sep 20, 2018 | 06:44 AM
99 Black Bird T/A's Avatar
What did the piston manufacturer suggest?
This would be a starting point...
Wiseco - piston ring gap and file fitting
Old Sep 20, 2018 | 06:49 AM
For a street car, go .0050” x the bore size for top ring. .0055” x the bore size for the second ring. This is per Wiseco”s recommendations. If this is a full on race deal, add .0015” to the multiplier.
Old Sep 20, 2018 | 06:57 AM
JoeNova's Avatar
Restricted User
I usually go .0075" x bore for top right, .0070" x bore for 2nd ring for a turbo build. Some will flip those values for top/2nd.
Old Sep 20, 2018 | 09:35 AM
KCS's Avatar
KCS
Moderator
What piston? It really depends on the heat the rings will be subjected to.
Old Sep 20, 2018 | 10:28 AM
Soflown's Avatar
Diamond pistons. I called them today and they provided for to to go to total seals website and they have a PDF chart. Which I supplied below.
They suggested, .022 for top and bottom ring with a bore measurement 4.010
File Type: pdf
