push rod length after heads milled .021
- Lift: 0.585"/0.585"
- Duration @ 0.050": 228°/230°
- Advertised Duration: 283°/286°
will it be advised to get push rods made or stock be acceptable. Running PAC 1218 springs
Compression raito squeaks in at 9.1
I took the advice and the motor runs great on the OE rods. Another benefit after reading many posts on the issue here, is that the LS7 lifter operates better with more preload. I believe but I am not certain that the 5.7 OE preload is set at about .0040 from the factory. The preferred preload, or at least what many members here suggest for an LS7 lifter, should be about .070 or so. So, my preload is now set at about .060 and the motor runs well.
I do not know what the best preload should be for the 5.3. But, I guess the OE sticks will work well for you. But, check it out.
The best way to proceed is to measure what length pushrods YOUR engine needs.
Bottom line, cam grinders should list the base circles of all cams, IF not stock.
