LS1 engine girdle
http://cgi.ebay.com/ebaymotors/ws/eB...909603824&rd=1
Not sure but looks like you need some different main bolts plus there could be issues with the windage tray, too.
But this is JZ'sTA your talking to, I tried a search and found this.
https://ls1tech.com/forums/showthrea...=engine+girdle
Didn't help much.
I will try again and see if I find some different results.
Didn't help much.
The bottom line is most people don't need them, but some people that do need them don't know it yet.
Kurt
).Looks like something that some of the more extreme motors might benefit from, but for the cost of the unit itself plus the custom studs, probably not something that the majority of us need to worry about. I would worry more about oil leaks with the thing than losing my bottom end without the thing.
All the other girdles that I have seen in magazines and such are constructed very differently....they are constructed so the bottoms of the main caps are tied together ...this one looks like it follows the outline of the oil pan, is installed under the caps and moves the caps away from the block by an amount equal to the thickness of the girdle....
Totally weird design....it looks like it would require differnt caps
It is on the bottom of the mains but, does not interfere with the oil pan rails.I think a stronger design would be like the one that Kurt mentioned in his post that they make that ties the oil pan rails and mains together.
My in itial reaction is that this girdle looks very thin and may not provide much extra reinforcement....
Any thoughts on the thickness guys?
I have one of our girdles on a stock cap that will see some boost before the end of the summer, after dyno we will disassemble and inspect mains.
Kurt
