Help with head work 2002 5.3
Old Oct 17, 2018 | 05:58 PM
5.3ShortBed's Avatar
Default Help with head work 2002 5.3
Hey guys, new to LS1TECH. I just bought a 2002 single cab shortbed silverado and I’m looking to start building. Starting with basics to help down the road first. I just bought a set of used 706 heads and ls6 trick flow valve springs that will handle .550 lift. I’m also buying a motor with 150k that just needs lifters. So all my work will be happening outside of the vehicle. I’m wanting to raise my compression. I few things I could do are mill the heads down by .030, use flat top/dome top pistons. But I was also wondering about valve clearance issues. What can I do to raise compression and avoid those issues? Also preparing for a mild cam in the future. What are some other things I could do worth my time and money on these heads?
Old Oct 17, 2018 | 06:26 PM
Hold on. In one sentence you want to LOWER your compression. THEN a couple sentences later you want to RAISE your compression? Anyway. by getting flat top pistons and keeping the 706 heads WITHOUT milling, your compression will be close to 10:1. How high do you want it?
BTW you will have no clearance issues even if you mill .030 and use flat tops with a mild cam.
Old Oct 17, 2018 | 06:35 PM
Sorry I meant raise. I edited that. But I’m wanting to raise it enough that I can still use regular gas for now and enough to get some more pep in its step.
Old Oct 17, 2018 | 06:39 PM
Then do NOT mill the heads. With flat top pistons and stock 706 heads the compression will be close to 10:1 as I said before.
Old Oct 18, 2018 | 01:32 PM
omc8's Avatar
Flat tops and 243s you have 9.9 cr Flat tops and 706/862 you'll be close to 10.5 depending on gasket
Old Oct 18, 2018 | 01:51 PM
Good call! The Gen IV 5.3's with 243's and flat tops ARE 9.9 from the factory. The smaller 706/862 DOES raise that to 10.5. Thank you for posting this. Now I have it straight! lol
Old Oct 18, 2018 | 05:29 PM
Thank you guys for the help! This is exactly what I was wanting to know.
