Small nick on block deck surface
Old Oct 25, 2018 | 06:32 PM
Rocky98's Avatar
Default Small nick on block deck surface
Im in the middle of a very basic street build on my 1998 LS1 block which is not going as smooth as I would like. Just got my short block back from the machine shop and notice this little dent scratch nick on the block deck. Im assuming thats a no go for reassembly so my next question is what are my options. Its about .010 deep as best as I can measure.
Shop is telling me it wasnt there when they finished which I already guessed was gonna be the case. Running a stock or very mild cam, bolt ons etc.
Old Oct 25, 2018 | 06:37 PM
Rocky98's Avatar
Old Oct 25, 2018 | 07:10 PM
s30.hybrid's Avatar
Damn thats aweful close to a critical sealing area. Im sure some might say run it as is, but itll be even more work if you have to fix it later after a head gasket leak. 10 thou is a significant amount to shave. I would look for a shop that can weld fill the void then deck the block
Not in a critical area. Run it. If you're worried put a little JBWeld in it. The head gasket will still seal well with the nick there.
Old Oct 25, 2018 | 07:27 PM
MY_2K_Z's Avatar
Jb weld for piece of mind and continue on with the build.
pdxmotorhead's Avatar
Yep,, a dab of good metal base high temp epoxy and touch up with a bit of 120 grit..
There is some really great stuff available in the HVAC industry for fixing compressors and other fun stuff..
Heck they change intake ports on heads with epoxy..
I wouldn't even think of welding that ,, a good job requires heating the entire block to prevent stress in the cast iron.. (IMHO)
Old Oct 25, 2018 | 07:35 PM
00pooterSS's Avatar
Smooth it flat and run it or fill it, smooth it flat and run it.
There's plenty of surface left for sealing around the coolant jacket and the cylinder. The cylinder liner is also perfect and that's a critical part, so you're good.
Old Oct 25, 2018 | 07:49 PM
Kfxguy's Avatar
I vote for Jb weld and sand it flat. It’ll hold it. Just make sure it’s clean inside there. Take a pick and scratch it up inside the nick.
Old Oct 25, 2018 | 08:58 PM
dixiebandit69's Avatar
As long as there is no raised metal around the dent, I'd just run it like that.
As Pooter said, it's actually not part of the critical sealing area (unless you're going to run head gaskets with much larger bores that might overlap that hole).
IF there is raised metal around the dent, file it flat with a bastard file using light strokes, and follow up with some high grit sandpaper, like 400 or higher. Then run it. I don't think the JB Weld is necessary, but I don't think it will hurt, either.
Also, for the record, I've always used copper gasket spray on any MLS head gasket I've ever used.
EDIT: Something I think should be mentioned is that the nick has plenty of good material around it, which is why I wouldn't be worried about it. If the nick started where it is next to the cylinder bore, and went all the way to the water jacket, then I'd be worried. But it's surrounded by good metal.
Old Oct 25, 2018 | 09:09 PM
Don’t weld that. It will distort the bore, and you’ll have to re-hone. Personally, I’d do as said above and carefully file the area if, and only if there’s a raised area around the nick. If not, spray your gaskets with copper spray, which I always do anyway, and run it.
Old Oct 26, 2018 | 12:42 AM
Rocky98's Avatar
Thank you for all the input! If I have some surface filler kicking around I will use that and sand smooth. Otherwise I think I will use the copper spray and follow the above advice. I checked with a guage block and there doesn't seem to be any raised metal around the dent.
Old Oct 27, 2018 | 08:12 PM
Dano 00TA's Avatar
If it was me, I'd also JB Weld it just to play it safe. Although it looks like it's seal the way it is.
Old Oct 27, 2018 | 10:17 PM
LLLosingit's Avatar
That looks like a bubble in the casting and probably uncovered when it was milled. As other have said it shouldn't be a problem, Lay your gasket on it and see where it ends up. If you do fill it just make sure it's well cured and flat before assembly.
Old Oct 28, 2018 | 07:00 AM
VandykeT/A's Avatar
Make sure its not raised around it and put it together. Itll be fine.
