Will it hit 450 whp
And as far as the shrouding issue, I’ve heard of guys squishing the Head dowls a bit to shuffle the head over to get the valve further from the cylinder wall. Really on a 4.030 engine you’d only have to shuffle the head over .015” to match a 4.060 bore
would be interesting to see on a 4” bore. See what the shrouding issue really means.
I crush the dowels. With the parting line at 12 o’clock, I squeeze on the 3 and 9 o’clock sides with a set of pliers, then install them in the block with the parting line pointing up towards the lifters. I think you can get .015” or .020” before having to slot the head or intake bolt holes.
Motion seconded
