junkyard 5.3 with 853 LS1 heads and intake thoughts?
Picked up a set of ls1 heads (853 casting) and intake for the cheap.Really just wanted the intake for my swap but guy tossed in the heads for $100. did some google searching and found mixed reviews on this set up. from what i researched this combo works best if the heads are milled .40 to get the engine back to stock compression however you would have the advantage of larger intake valves. i know the 243 heads are better however i already have these so i kinda just want to wrk with what i already have.
i dont have the bottom end yet. planned on getting a junkyard 5.3. swap in going into a 95 impala ss . any info would be greatly appreciated.
You'd be better off with the 5.3 heads. 706 casting probably if it ends up a 02 - 06 or thereabouts which is probably the eeeeziest one to use. Same for the intake: if it'll fit (no idea in that chassis), the truck intake is better. The 5.3 doesn't benefit from the larger valves in most situations. Just get a whole 5.3 and use it as much as possible as-is, but watch out for the Castech issue. Maybe change the cam but not the heads or intake.
Even a fairly mild cam will make that 5.3 feel a lot more lively. Look for "drop-in" cams that CAN use the OEM springs, but put some stouter beehives in it anyway for better valvetrain stability.
On a 5.3 the stock LS1 853 would yield about ~9.85 to 1 compression with a stock gasket. Chamber is probably about 66cc.
On a 5.3 the stock 706 truck head would yield about ~10.4 to 1 compression with a stock gasket. Chamber is probably about 61.5 cc.
NA, I'm not a fan of the 853 heads on the 5.3, due to losing the ~.5 pt of compression. The 853's bigger valves don't help on the 5.3's small 3.78 bore.
I'd sell the ,853's for a $100 and use that toward 243's or 706's etc.
We did similar once. Used 853, Milled 50 or 60? off ( it did mark the pistons up a little so be careful and clay test/notch if need be ) on a super cheapo budget deal with a 228? I think it was cam. long tubes, ported tb, and a good tune up. second gen Car ran mid 12's all day on pump 91
Restricted User
If you plan to boost it, then use the 853 heads.
If you want to run it NA, then you will need to mill the 853 heads quite a bit. You would be better off using the heads that the 5.3 comes with from the junkyard.
