6.0 Engine smoking on driver side exhaust only.
Quote me where I said anything about a head gasket.
It's easy, find my post, click quote then point out where it says anything that has to do with a head gasket.
When you don't find it, write me a letter about how dumb you are, start the letter with Daddy, I'm sorry I can't read and I'm so stupid... you take it from there.
I don't know what Rockin is smoking/snorting/shooting/drinking/rubbing into his belly, but it has to be some good ****...
Not ONE reference to head gaskets by Pooter. Was curious in case anyone missed something....
Well I've got my
I had time today to finally pressurize the cooling system.
i found where the water leak is, it’s at the upper water pump outlet where the hose meets at.
The clamp was tight enough to keep it from blowing off with the bevel on the water pump neck but not tight enough to stop a leak.
At 15lbs it came out quick on the back side of the outlet and that’s why I was losing that much coolant. I had a friend tighten all clamps during this swap, I guess that last one was when his side chick sent him nudes and he forgot to fully tighten it.
Dummy me....
Went back and tightened all clamps, pumped to 16lbs and no leak anywhere.
it kept in between 15-16 lbs for over 10 minutes, so no more water leak any where, one thing fixed.
I’m going to drive it around again, since the coolant leak is fixed and see what happens next.
Will-update again
Dummy me....
Will-update again
