Engine Compression ??
Thanks
Chris
I'd be curious if the cam is off timing or it may just be that the rings are dry.
Put a little oil in each cylinder and turn the motor over several times and do another compression test. Also try another compression tester, I've had a compression tester bite me before.
A 5.3 with stock bore, flat tops, stock head gaskets and stock cc 317 heads gives 9.3:1 compression. I'd go for higher
With dish pistons it will be around 8.7
Slap some 706/862 truck heads on it or some 243/799's
The cam profile and cam timing plays a part in static/cranking compression. But if you're close to 10:1 you should have around 170 or so, hard to nail that down since so many factors play into that.
There are other factors at play here, Valve events alone can cause low compression test readings and so will ring gap.
My 12:1 compression ratio engine would only pump to 140-150psi and my stock 9.5:1 street engine would pump to 170-180psi.
For the most part the numbers are meaningless in most cases, We always broke in an engine and then ran a compression and leak down test to get a baseline so as the engine aged we could compare numbers cylinder to cylinder to keep track of it's condition.
I would just pull the heads. It's not much work. And the MLS gaskets can be re-used 2-3 times; so it won't cost you anything but time.
Seriously though, just so we're all on the same page, when you're doing your compression test, how many needle pulses are you going for? Because if you're just cranking it over one revolution, it will give you a really low number.
I generally go five pulses.
Barring some major mechanical problem, if you still have compression that low, I'd suspect that the cam might be installed retarded. (out of sync with the crank, not stupidly)
