Speed Inc TU1.5 valve springs
I got a cam and spring kit from speed inc years ago that I am finally installing.
TU1.5 cam
Duration @.050 is 228/228, Lift is .571/.571, and is on a 112LSA.
Came with these springs.
PRC .675 lift duals
Install Height: 1.800"
Closed Spring Pressure: 157lbs @ 1.800"
Open Spring Pressure: 471lbs @ 1.125"
Maximum Spring Lift: .675"
Coil Bind 1.060"
Spring Rate: 483lbs/in
Are these springs a little much for this cam? Or just run em? Stock rockers and new LS7 lifters. Thanks.
TU1.5 cam
PRC .675 lift duals
Coil Bind 1.060"
