Cam help
Old Jan 3, 2019 | 10:24 AM
boostedstang's Avatar
Default Cam help
I'm doing a ls swap in my c10 and looking at cams.Ive got a 2004 lq4 and looking for 4l80e. The last NA 6.0 I put a texas speed v2 in and it pulled and sounded good but was looking for something that sounds more aggressive if possible without killing power down low or the drive ability.The motor is stock I'm going to get the heads worked and maybe shaved some for comp.It will have a stall and 411 gears.I called texas speed and they said that the torquer v4 or the tusmie v2 would be good. What do you guys think I'd like it to sound pretty mean and run good.would one of these cams be good or just stick with the v2 like I had before or get a custom grind from someone?Thanks for any suggestions.
Old Jan 3, 2019 | 10:26 AM
Mavn's Avatar
"I MAID THEESE"
Tsumani v2 will do fine .
Old Jan 3, 2019 | 01:23 PM
OK guys- Today's spelling lesson; T S U N A M I...…..
Old Jan 3, 2019 | 01:40 PM
Summitracing's Avatar
LS1Tech Sponsor
Beautiful Truck! If you're open for suggestions, we'd like to throw our Summit Pro LS Truck Stage 3 and 4 into the mix. The Stage 3 Truck (SUM-8713) is a 222/231 112 + 5 .545/.545. Intake opening is 4 btdc for a strong idle and closes at 38 abdc for killer midrange and torque. The Stage 4 Truck (SUM-8714) ups the ante by a few degrees at 226/230 112 + 4. Intake opening is a degree earlier, but we extend the exhaust closing to 41 abdc to extend the rev range and make more power up top. Both have excellent lobes and will pull hard past 6k with inexpensive LS6 valve springs.
__________________
800-230-3030
www.SummitRacing.com
Old Jan 3, 2019 | 01:46 PM
Thanks summitracing.Im Definitely up for suggestions on cam .would your stage 4 sound pretty good?And sorry for the spelling wrong g.TSUNAMI V2.
Old Jan 3, 2019 | 02:10 PM
LS1Tech Sponsor
Depending on where it's advanced, a 111 lobe separation Tsunami opens the intake valve around 8 btdc. That's going to make it lope harder than our Stage 4. It's closing point is around 46 abdc which is why your low end torque and mid-range aren't quite where you want them.
If you're looking for more driveability, you could drop the idle down a bit with the SUM-8714 Stage 4 and it will still make more low and mid range power. It also allows you to mill the heads a full .030 for more compression. Compression will make it stronger everywhere.
Another option if you're looking for a "Tsunami-like" idle with more bottom end is our Cca-SUMLSGT102 cam. It's not one of our Pro LS cams, but it's made for us by Comp. It's specs are 230/234 111 + 3 and .600 lift. I/O 7 ( Strong idle), I/C 43 (more torque), E/O 53, E/C 3. It sounds a bit closer to what you're looking for if you liked the V2.
__________________
800-230-3030
Old Jan 3, 2019 | 02:38 PM
K I'll check them out I definitely want it to sound at the least like the torquer v2 I had did.I know it's not all about sound but I do want it to have a healthy sound.I'll see if I can find some video clips of you pro series cam.
Old Jan 3, 2019 | 02:44 PM
LS1Tech Sponsor
I wasn't able to find vids for you on that particular cam but searching for 230/234 cam did net some good results
__________________
800-230-3030
Old Jan 3, 2019 | 02:51 PM
No biggie, man! I couldn't resist since Mavn messed it up too! LOL
Old Jan 3, 2019 | 03:05 PM
Lol I didn't even notice it till you pointed it out.
Old Jan 5, 2019 | 06:30 PM
I got the heads off and cam out and looks like I may need to do a whole rebuild.Heres some pic of cam bearings I've only built 2 ls engines and 3 cam swaps but the ones I just did cam swaps in I don't remember the bearing looking like this what do you guys think.
Old Jan 6, 2019 | 10:36 AM
I got with ws6store and he suggested his asa high lift cam.Has anyone put one in a 6.0 and if so how did it perform and sound compared to the v2 or v4?I'm going to be getting my rebuild kit from him more then likely seems like his prices are good and he responded and answered any questions I had and that means alot to me
