Good quality Rotating Assembly kit
Flame suit on...LOL...
No flames here, it all really depends on what the OP wants.
Basically if the power goal can be met naturally aspirated with cubic inches, great heads, etc that would be my preference. If the power goal can’t be met NA and maintain streetability then don’t worry about cubic inches and just run more boost to achieve the goal. That’s my opinion and there are a ton of combinations available which makes it fun.
I was just about to ask a similar question. I'm glad I saw this thread. I would really like a Pro-charger, but I'm concerned about my stock pistons. It seems like 600 whp is about the limit on the stock pistons. A set of forged pistons would be sweet, but I haven't found any in the stock bore. They are all 3.903-.3.905".
Back in 2002-2003 had a friend making ~680 wheel hp in his procharged 02 SS Camaro. The tuning software wasn't as good then. The stock pistons held up fine. Eventually the oil control rings wore out and started giving puffs of blue smoke. Still ran good, in the low 10's, just needed re-ringed.
Honestly, I think 600 whp is way too much for a street car/daily driver. I'm just thinking that's about where we are going to end up with a little heads/cam/intake work on a Pro-Charger. I'm currently at 382 whp. Pro-Charger typically advertises a 50% increase. So, I would probably end up around 570-580 whp...?
For what it's worth on street tires at near 600 rwhp in 50 degree temps I can blow the tires off so easy from a 20 mph roll it's like reving the car in neutral. This is with a procharged 346 which is not a low rpm torque monster setup. You'll have plenty of fun with a 600 to 700 rwhp 347 on the street.
