LS1 to LS2 conversion question?
Old Jan 16, 2019 | 07:55 PM
curtisad's Avatar
Default LS1 to LS2 conversion question?
What parts from an LS1 would convert over to a LS2 block, for example heads, oil pan, alternator, water pump, etc, etc? Am wondering if I should just buy a forged rotating assembly kit for my existing LS1 from Texas Speed or get a LS2 block and rotating assembly and be able to switch everything else over?
Old Jan 16, 2019 | 09:41 PM
wannafbody's Avatar
LS2 has a larger bore which is a plus. Might be able to find one salvage, ebay or classifieds. Most things swap over. I think knock sensors might be different.
Old Jan 16, 2019 | 09:57 PM
bammax's Avatar
Knock sensors move and just about everything else is interchangeable. The LS2 would give you more cubes, but make sure it's not the 58x relucter if you're putting in a LS1 car. Basically look at the total cost start to finish, add 10% for incidentals then figure out which is the best bang for your buck.
