White Smoke
Old Jan 22, 2019 | 09:09 PM
juniorz28's Avatar
Default White Smoke
White SmokeHows it going so about 3 months ago i finally got my car running again after being down for 1 year. So I did a radiator flush and changed the oil after 2 days i started noticing some white smoke coming out of the exhaust ( heavy smoke) so i thought i had a bad head gasket, maybe water was going through the exhaust valves which was causing the smoke. So i replaced the passenger side gasket as I'm taking out the spark plugs i noticed oil in them, BTW the head gasket was bad which i hoped solved the issue. after a day of running it same white heavy smoke came out of exhaust again, CAR has 139K miles on it Im thinking its bad piston rings? I'm hoping to solve this issue ASAP any info or any of you guys have dealt with this issue pls feel free to share. thanks
__________________
Old Jan 22, 2019 | 09:52 PM
bammax's Avatar
White smoke is burning coolant. Check your other head gasket.
Old Jan 22, 2019 | 11:03 PM
jetech's Avatar
Veteran: Air Force
Do a cylinder leak down test. It will point you in the direction of the failure
Old Jan 24, 2019 | 02:46 PM
Ls7colorado's Avatar
are you loosing coolant?
are you losing oil?
Excessive oil can also be white/bluish
and cold weather will obviously put out white steam too
Got a video?
Old Jan 24, 2019 | 09:34 PM
juniorz28's Avatar
im not losing either or car runs good just the fact that the car throwing white smoke and its not from a cold start up.
juniorz28's Avatar
thank you
Old Jan 24, 2019 | 09:54 PM
Can you post a video?
Old Jan 27, 2019 | 10:18 AM
rednari2's Avatar
White smoke when its not from a coolant leak, usually means the valve seals or guides are worn. Check the seals first, they can be replaced without removing the head.
