Trickflow top end kits
Old Feb 1, 2019 | 09:17 AM
86CAMARO400HP's Avatar
Default Trickflow top end kits
Hey everyone. I'm finally in the clear to start my build. What I have is an iron gen 3 -5.3 block that will be torn down , machined to ls1 specs,and rebuilt by a good friend of mine.
My question is, has anyone tried those trickflow top end kits for ls1. They have a 480hp, 500hp, and 515hp kit I believe. Kit includes heads, cam, pushrods, roller rockers, bolts, gaskets, etc....
The motor will go in either a 86 camaro or 81 c10. Not sure yet... It will be a street vehicle, not much track time. I really want something I can keep up with or leave the new camaros, challengers, etc.... (not the top of the line models)
Old Feb 1, 2019 | 12:17 PM
Summitracing's Avatar
LS1Tech Sponsor
These kits were all developed on the dyno. The engine will definitely make what they say it will if not a little more even.
__________________
800-230-3030
www.SummitRacing.com
Old Feb 1, 2019 | 12:31 PM
Do the hp # include drivetrain loss?
Old Feb 1, 2019 | 12:43 PM
AnotherWs6's Avatar
https://www.hotrod.com/articles/ccrp...m-ls1-package/
The cams seem pretty conservative. And I know this article is using carb intakes. One thing to note is that although they hit 500hp, they did this running no accessories, electric water pump, open headers, in a climate controlled room and dyno water cooloing the engine, meaning it probably doesnt get up to 150 degrees. Put that setup in a car and dyno rwhp and you're most likely gonna end up at around 400rwhp. Not very impressive.
The cam is mild though.
Old Feb 1, 2019 | 12:57 PM
Ls7colorado's Avatar
Of course not, WAY to many variables for that
Old Feb 1, 2019 | 01:11 PM
Darth_V8r's Avatar
Moderator
Those are flywheel HP numbers not rear wheel HP numbers.
Old Feb 1, 2019 | 01:12 PM
LS1Tech Sponsor
We generally see about 12% loss on a Corvette Drivetrain and closer to 13% on a stick F-body on a typical Dynojet. Trucks it can be hard to tell based on the wide variety of wheel and tire options that can add weight quickly. Trickflow spends a lot of time looking at area under the curve, so their packages run better than the peak number would suggest.
__________________
800-230-3030
Old Feb 1, 2019 | 01:24 PM
yea, thats right about no accessories, climate control, etc... but 400 rwhp is around 460-475 hp estimate?
Old Feb 1, 2019 | 01:34 PM
LS1Tech Sponsor
The 500hp package would make about 435 to the wheels with a decent exhaust system on it.
__________________
800-230-3030
Old Feb 1, 2019 | 02:42 PM
Ok gotcha. I probably would just go with a top end kit since it comes with matched/supporting needed parts.. thanks. I see summit has these kits too, so I will keep that in mind
Old Feb 1, 2019 | 02:44 PM
LS1Tech Sponsor
Glad we could help. You're really going to like how the package performs. It will transform your car.
__________________
800-230-3030
Old Feb 22, 2019 | 01:46 PM
Muadi's Avatar
I purchased the Trickflow top end kit for my LS2 through Summit, I assume it would be similar to the LS1. Been very happy with them so far. They dyno told me 452hp at the wheels. I have about 5000 miles on the assembly so far. No issues, no drama really. The only issue I had was the Harlan rockers that were apart of the assembly had a slight touch condition on 3-4 of the rockers with the stock valve covers. After a little clearancing of the valve covers, all seems to be good now. I recommend the kit.
