Swapping to Gen 4 rods worth it?
Old Feb 21, 2019 | 10:41 PM
86CAMARO400HP's Avatar
Default Swapping to Gen 4 rods worth it?
Hi all. For my estimated 400- 450 rwhp estimate, is it worth going with gen 4 rods?
The engine I'm rebuilding is gen 3 and plan to reuse/recondition block,crankshaft and connecting rods
Old Feb 21, 2019 | 11:39 PM
There are Gen III's all over putting out the power you want without issues. Unless you can get a real killer deal on a Gen IV set of rods I would not loose any sleep over it.
Old Feb 22, 2019 | 08:27 AM
Aaron at SDPC's Avatar
At that power level you'll be fine. Keep on rolling with what you have.
Old Feb 22, 2019 | 11:27 AM
truckdoug's Avatar
i'll play devil's advocate. if you're gonna be doing pistons might as well throw another $100 into the fire in case you get the turbo bug.
Old Feb 22, 2019 | 01:41 PM
panda240ss's Avatar
400 500hp the gen3 can take easyyy no worries. now i think 700 750 you are on borrowed time.
im going to be doing 600 650 turbo e85
Old Feb 22, 2019 | 03:06 PM
Besides size and thickness, what is the difference between gen 3 and 4 rods. I see something about floating rods for gen 4.
Old Feb 22, 2019 | 03:07 PM
panda240ss's Avatar
...size and thickness = strength....isnt that enough?
Old Feb 22, 2019 | 03:32 PM
I think gen 3 is press fit and gen 4 is floating? If I go with Gen 4 rods, would I need any additional supporting parts that the gen 3 doesnt have?
Old Feb 22, 2019 | 04:46 PM
panda240ss's Avatar
for your power goal you dont really need gen4 rods.....TBH
unless you just dont trust gen3 rods or your bearings or something are foooked!
Old Feb 22, 2019 | 05:25 PM
No , I was just asking. I will stick with gen 3. Thanks everyone
Old Feb 22, 2019 | 07:38 PM
gjestico's Avatar
The bushed rods are about 30 grams heavier. I wonder if you would need to rebalance the entire assy ?
