Introducing..Summit Pro LS Forged Pistons!!!!!
What is the reality though? We all know someone that built an engine on a dirt floor and was successful.
Let's start off with the first comment we hear... "The cylinder is like new, you can still see the cross hatch". The problem is a cylinder will still have cross-hatch at 200k miles and still be completely worn out because the crosshatch may be up to .008" deep to begin with. The result is excessive piston to wall. Smoke, Oil Consumption. Piston Slap etc. Remember even .001 over our .004 "metal to metal" spec is 25% more than we recommended to begin with.
So how do you measure it? Unfortunately, this is beyond feeler gauges and snap gauges. Dial bore gauges only accurate to .001 in. are better, but if you've ever used a quality dial bore gauge accurate to .0001, you will feel naked if you are forced to use anything lesser. Not many hobbyists have those tools though.
Option 2: Ok, so 90% of folks don't own a good dial bore gauge and/or 4-5" Transfer Micrometer. What's the next criteria to having success with a standard bore piston? Well, best case scenario is you are running a low mileage engine and it hasn't been opened up and sitting. Metal sweats in changes in heat/cold and it rusts.
So what hone to use? Never use a three stone hone for this type of work. We're all familiar with bottle or "dingle ball" hones and the Brush Research Flex Hone are the best of the bunch. This is the part number most commonly used with LS 5.3 through 7.0L engines. Here are the instructions. Another option we like is the Wiseco W6079 Soft Hone Brush...it cleans the bores without removing the material...meaning less chance for error by the operator.
Lastly, Clean the bores with acetone and white paper towels until they absolutely come up clean. This might take 30-45 minutes or more. A lot of stones and dingle ball brushes use aluminum oxide abrasives. ANY left in the bore will come loose and quickly wear out EVERYTHING.
This is really just the tip of the iceberg, but you really need to consider this before making your decision to stay standard or hone or bore/hone. We haven't hit on the importance of torque plate honing and often "sending the boring bar" down a perfectly good looking bore at .030 over won't clean up all surfaces.
however I'm still having some trouble understanding exactly ,
It seems like you are suggesting to take original engines with 50k-200k mileage and hone them out for STD+.005" style pistons,
And that it will be very rare to use actual STD size pistons unless the engine has less than 50k mileage roughly
Also to clarify our earlier comment about honing. A bottle brush is just there to get the cross hatch and it's not designed to get you up to the next available bore size like 4.005 for instance.
As for method, it is best for the machinist to use a micrometer to measure the piston and set the micrometer off that.. Then they use the micrometer to set the dial bore gauge. Then they use the dial bore gauge to hone the cylinders in relation to the pistons. This is the best way to make sure fluctuations in shop temperature are never an issue.
Thank you for your patronage!
The only thing, and it may have bene mentioned but it wasnt quite clear to me. Is the compression height is lower than expected. What i mean by that is that with a STD deck height in my block im .010" BELOW the deck.
Not a problem for my deal since its turboed, but might be a problem for others. Also, if you do the math and consider a stock deck height of 9.240 they come out to 10 below the deck.
This is for a several reasons. The iron blocks from the factory varied between 9.230 and 9.240. We didn't want anyone unexpectedly find our pistons tapping the head. If you have a True 9.240 deck, you can run a commonly available. .040 gasket (or less) to hit the factory quench if people are hunting for compression. Finally they aren't making Gen. 3/4 any longer and we expect the blocks will need the decks trued up in the future as people drag them out of the boneyards and want to rebuild them.
My rods are 6.125 summit.
.010" below the deck... also using the wallace racing calculator i come up with .01"
I have now stock LS1 gasket for this build. I think they are .51 thickness.
What compression I will.make with 59cc heads?
Do you recommend decking it so my quench be better?
What are you thinking about for fuel and how much cam do you have in it?
