Engine internals balanced
Old Feb 3, 2019 | 11:55 PM
Jmaitland806's Avatar
Default Engine internals balanced
Im going to have my crank balanced to the forged pistons. What all should i have? I believe the shop listed pistons, rings, crank, harmonic balancer, and maybe flex plate? Now ill be switching to a th400 should i get a new plate that would match a th400 instead of 4l60e to send with the internals or will he even need the plate for balancing?
Old Feb 4, 2019 | 12:22 AM
LS engines are all internally balanced, so don't really need the crank damper or flexplate as they are balanced individually.
Old Feb 4, 2019 | 05:48 AM
99 Black Bird T/A's Avatar
I would add "Connecting Rods" to the list.
Old Feb 4, 2019 | 06:01 AM
KCS's Avatar
KCS
Moderator
You will need the pistons, rings, pins, clips, rods, and a rod bearing. As G said, the LS cranks are internally balanced, meaning the crank is balanced independent of the dampener or flywheel/flexplate. However, its not a bad idea to have the shop check their balance independent of the crankshaft bit I have yet to find any that weren’t balanced from
the manufacturer.
