Cam sensor troubles
Old Feb 10, 2019 | 05:32 PM
LOWnEASY's Avatar
Default Cam sensor troubles
My 99 5.3 is having cam sensor problems that came about after the cam swap. I've change the sensor, pig tail, check power on the red wire, and checked continuity from plug to pcm on the pink and brown wire all that checked out and dont know of any other test to do on the wiring side.
pulled the front cover and cam to check the reluctor on the cam and it looks fine as well, cam gear was tight and no front to back movement. Any one have suggestions on what to check? Grounds look good and clean and snug as well.
Old Feb 10, 2019 | 08:29 PM
Whose cam sprocket are you using? It might be out of spec. Also, whose sensor are you using? Non-GM sensors have been reputed to be of lower quality than the genuine article.
Old Feb 10, 2019 | 10:00 PM
LOWnEASY's Avatar
It's a gen3 with the reluctor on the back of the cam. And I am using a parts house brand sensor, but also tried another known good oem sensor that also didnt work
Old Feb 11, 2019 | 06:51 AM
Check the grounds on back of both heads. Maybe the cam sensor location has dirt under where it bolts to, and won’t allow the sensor to sit low enough in the block?
Old Feb 11, 2019 | 03:43 PM
LOWnEASY's Avatar
any other ideas to try before i put it back together? or is there a way to test it with the engine not running? (using hpt scanner to see cam signal)
Old Feb 11, 2019 | 04:08 PM
00pooterSS's Avatar
How far apart is it?
It would be a real good idea to closely inspect the tone wheel (the part the cam sensor picks up) on the rear of the cam. If you can, yank it out and compare it real closely to the cam that came out that I assume wasn't giving you any trouble.
Check the shape, sizes, lengths diameter everything. The sensor has to be real close to it to read so if it's smaller or mishaped it wont read properly
Old Feb 11, 2019 | 04:09 PM
00pooterSS's Avatar
Also what problem are you having? Did anything change after you replaced the sensor and pigtail or is it the same exact issue with the previous sensor and pigtail?
Old Feb 11, 2019 | 04:10 PM
00pooterSS's Avatar
Checking those grounds is always a good idea. I've seen it be an issue many times and it's never safe to assume they are good. I had a suburban in recently that someone rebuild the transmission on and they for some reason loosened those grounds and didn't tighten them all the way. They can also work themselves loose if at any time they were removed and the bolt wasn't tightened enough.
Old Feb 11, 2019 | 05:58 PM
LOWnEASY's Avatar
the problem is cam sensor signal code and also the cam hi to low/low to high signal isn't getting reported to the computer verified with hptuners scanner, and some times the truck will fire right up and most the time it has to crank a bit before it fires (and some times have to stop cranking and then try again), and has the goofy sounding backfires when its cranking. nothing changed from before to after the sensor and pig tail change.
I'm going to redo the ring terminals on the ground wires wile its apart.
i currently have the cam out to check the tone wheel on the back and the intake off so its easy to get to the sensor
Old Feb 11, 2019 | 07:35 PM
00pooterSS's Avatar
Make sure your wiring is in good shape several inches if not a foot or so up the harness. I've seen similar stuff because the old wiring started to rott out and the wires were bare.
Did you ohm all 3 wires to the computer?
And did this 100% start with the new cam? If so look mostly at the cam.
Old Feb 12, 2019 | 10:57 AM
LOWnEASY's Avatar
Ohm'd all 3 wires and all were good the problem did start with cam swap and I compared the tone wheel to the old cam and there identical. Not sure what Els it could be.
Old Feb 12, 2019 | 11:04 AM
00pooterSS's Avatar
I'm a tech and run into your situation sometimes. Not exact situation but a situation where something is off and you start thinking of everything. Keep what changed in mind. No issues until the cam swap and you haven't gotten them to straighten out no matter what you've tried with that cam in there. That logically leads back to the cam itself. You may have to put the old cam back in to test the theory but that's a major beoch just to do a test.
Did you use a caliper and measure the circle on the cam/tone wheel? If the one on your new cam is a hair smaller it may be too far from the sensor for it to accurately read.
There must be something going on with the tone wheel or the cam. Is the new cam magnetized? How about the old one? Try touching a screw driver or something to them and see. I've never checked for this but often wondered if it could cause an issue with a magnetic pick up sensor. I'm just throwing mud at the wall at this point.
What codes are you getting specifically?
Do you have a fluke meter or a high end meter?
Old Feb 12, 2019 | 11:22 AM
00pooterSS's Avatar
Have you looked through the cam sensor hole to the cam to make sure there's no debris or anything that may have gotten shoved back there during the cam install? Big wad of grease/assembly lube or.. who knows what?
Old Feb 14, 2019 | 10:22 AM
bbond105's Avatar
I have never tried this before, but I am wondering if you could spin the cam fast enough by hand to get a signal on a volt meter or scanner.
Old Feb 14, 2019 | 11:18 AM
00pooterSS's Avatar
You can but you wont always see a signal based on what you're using, and also how fast it spins.
If you want to for sure see it use a graphing meter (has a bar graph), I use a Fluke 115, and I know the 78 and 88 also have a bar graph, I'm sure there's others but I don't know them all off the top of my head. You can watch the bar graph while cranking it too and watch the bar flick back and forth near full swing across the screen, but the voltage wont change much because the voltage swing is too fast for the display to reflect but the graph will show it. Spinning it by hand you may be able to see it in voltage but for sure you will on the graph, I've never tried it.
The best thing is an oscilloscope if you have one. But that's $$$$$$$
