VW Bug Sounding LS1?!?!
Old Jul 11, 2004 | 03:08 AM
CaptUSA's Avatar
Default VW Bug Sounding LS1?!?!
Okay, I picked up my car today from the mechanic. I was so happy to get it back, I didn't even do the normal fine tooth comb bit when I got it back, just blasted back to SD w/ some good tunes for the first time in almost a month. Well, once I calmed down a bit, I noticed that whenever I'm giving it ANY throttle, I'm hearing a VW bug engine sound. It sounds like it's comming from the left side of the car. Anybody ever hear of this before? Thanks.
Old Jul 11, 2004 | 03:10 AM
CaptUSA's Avatar
Oh, and BTW.... The work I had done was a head gasket R2, and and EGR tube that was fried. Thanks again fellas.
--Scott
Old Jul 11, 2004 | 03:53 AM
Z28Venom's Avatar
Sounds like an exhaust leak. Check to be sure that they tightened the header on after the gasket install.
Old Jul 11, 2004 | 09:29 AM
Bad30th's Avatar
Exhaust leak.
Bad30th
Old Jul 11, 2004 | 12:44 PM
CaptUSA's Avatar
Is it something I can get to myself, or am I going to have to takei it in? Thanks so far.
Old Jul 11, 2004 | 12:51 PM
strokedls1's Avatar
You can do it yourself. Check out the gasket though. If you have a bad exhaust leak it burns the gasket up. I've burned two collector gasket from the bolts loosening up. Now I use lock washers.
