Looking for cam upgrade. Need cam gurus Dyno inside
There is nothing about your combo that should not rev. I suspect valve float. That curve is not power falling off. That curve is the engine trying to tell us something.
You said you have 660 capable springs. What seat pressure, what open pressure?
What about pushrods? You should be running 11/32 or maybe even open the bosses for 3/8.
Also what lifters? What rockers?
Open Spring Pressure: 415 lb. @ .660" lift
Maximum Spring Lift: .660"
Coil Bind 1.015"
These numbers are from texas speed I have not tested them.
Morel Link bars 5294
Push rods are nothing special they are the texas speed hardened ones. 5/16 crome-moly.
I am thinking about upgrading to roller valve rockers and maybe I need bigger pushrods? the TSP salesman told me the 5/16 would be more than enough.
I did reach out to a couple cam folks. One said add 10 degrees to the intake and exhaust and 114+4 108 centerline. The second wanted .675 lift ex and intake add 10 degress also on a 108.
Moderator
Received 1,836 Likes
Closed Spring Pressure: 160 lb. @ 1.810" Installed Height
Coil Bind 1.015"
Coil Bind 1.015"
if you do upgrade to roller tips, you'll be heavier over the valve tip, so you'll want to bit more spring pressure to compensate for the mass. 11/32 x .120 is over 2x stiffer than 5/16 x .080 fwiw.
Wild solution suggested based on hearsay,,,, When the exhaust is moving through the system, if there is a pinch point, gasses will exceed the speed of sound, it will "quench" in that pinch point, when your on nitrous the burn is hotter and longer and scavenges in the pipe because its still burning which means a reduction in volume as it leaves the cylinder headed down the pipe. Certain styles of mufflers,, where the gas has to flow through a hole, can restrict so much more than a glass pack.
Think of it like a restrictor plate on a race car, once the flow goes supersonic the shockwave basically closes the diameter of the hole killing your power.
I ain't a physicist,, this is just how it was explained to me.. By a guy who was.. he told me thats part of why the Venturi on a rocket is so important vs the bell size.. mis match and big kaboom.. Or it doesn't make good power.. Its also part of why a 5cut valve job flows so much better than a 3 cut..
YMMV, you may want to carefully look at your exhaust and see of you have any joint of component producing a significant change in size..
On your Na run ,peak power and peak torque same rpm? Odd
I would look into that . If it pulls on juice higher rpm. Na burn speed maybe to slow. Burn speed to slow.no rpm.
I ran it thru pipemax as well.
Took to a couple speed shops. General consensus is exhaust holding it back like is suggested. The main problem is everyone wants 3k to build a good set of headers. Nothing is commercialy available for my set up. guess I'm gonna have to bite the bullet soon for headers.
If you cant tune it on e85. Try a fuel with less specific gravity. Like vp ms109. Power just may jump alot na. Or just use av gas and 4 ounces of acetone per gallon. About same thing. I would have to look at my dyno notes on the exact amount of acetone to match some of the faster burning fuels.
Fuel with less btu but burning 95% of it, is better then a high btu fuel and only burning 85% of it.
I believe the nitrous is sort doing the same thing .
This is something the dyno only knows.
Lsbmer,
Did play with timing a bit. Anything over 28 degrees and it starts to lose power. Got to make a couple hits. It's definitely likes the juice. picks up a sec on a 100 shot. and 1.3 seconds on a 150.
If you have access to a dyno. The cheapest thing is to change the fuel and re time/jet it and see what happens . It may surprise you. Just make sure you use a low specific gravity fuel.
Good choice on lifters. I would DEFINITELY be running bigger pushrods. Look into Manton series 5 -- 11/32 x .120. On a normal compression ratio (11.5 or lower) I would agree 5/16 is likely fine. You're almost 13:1. Higher cylinder pressures. I would be running as beefy a pushrod as I could fit. Typically I run 11/32 on an 11.5:1 engine just for good measure. You may also want to shim up the springs about 0.020 to gain a bit more seat pressure.
I don't have a good answer for you there. I could only make guesses. but my old 237/245-112.5+2 in my old 346 peaked at 6850 just fine and carried to 7600. And that was a plastic intake, not the carb style you're running. Your cam is already bigger and has a later IVC. So just going to a bigger cam with an even MORE later IVC I don't think will accomplish what you want.
Interesting part here. 1 valve and rocker had obvious signs of not being perfect. I measured the pushrods. It was exactly 7.400 inches. I went ahead and measure the rest of the pushrods and they were 7.420 inches but stamped 7.400.
So the out come out of all this is it seems the morels like preload on the heavy side. I ended up ordering rods that gave me a .084 preload. Its was weird the MT pushrods were stamped and measured 7.400 inches and the Texas speed rods were stamped 7.400 but measured 7.420.
