Mahle 3.908 Piston
Recently I bought rotating assembly kit for my LS 6, which consist of 3.903 Wiseco, Lunati conn rod, and K1 crank, got them balanced, packed and shipped to my home country, Indonesia.
And sadly that's the end of the happy story.
The problem began when I brought it to a machine shop to get the block honed, the machinist misinterpret the piston card, and I ended with 3.9065 wide cylinders.
Wiseco's requirement for PTW clearance is .0035, with my 3.9065 bores it put me at .007 PTW clearance, which too much.
I'm thinking to replace the pistons with 3.908 Mahle, however, from my search, I read that their advertised weight is 398 gram while my 3.903 Wiseco weight 446.20 at the lightest, that is almost 50 grams gap.
And here in Indonesia, unfortunately, there's no machine shop that could rebalance my crank.
Does any of you guys have use 3.908 Mahle and could confirm the advertised weight is correct?
Do you guys have any advice on which route I should take regarding this matter?
Thank you.
My current pin weight at 131.40 grams, in order to match the weight, assuming that Mahle advertised weight is correct, I need to get 180-ish grams of pin right?
Another thought, what if I get 3.905 Wiseco piston, that is .005 PTW clearance there, and maybe, just maybe, with some coating job on the pistons I could get away with .004 PTW clearance, will that work in this situation?
Coming from same company I know the weight gap between those two will be so close for me to be able to work with it.
Ordering & balancing another crank is my last option, the shipping cost is killing me.
So do you think this route will work fine on my situation?
New piston set will be way much cheaper than shipping cost for a new crank (or a new block)
