Need some Help
Old Jul 11, 2004 | 10:24 PM
camaro98z28's Avatar
Default Need some Help
OK... My car has over 121,000 miles on it and I have recently installed a TR 220/220 114 LSA, Comp 918's springs, Ported Oil Pump and a 255 lph Walbro Fuel pump, "NO Tuning Yet". and the car seems to be acting up, but only in the last month. It seems to serge when I get on it. Could My Injectors be going bad?
Old Jul 11, 2004 | 10:28 PM
soundengineer's Avatar
Describe Surge when getting on it.....
-surge-
Bogg down first??? bucking???
-get on it-
lead footing or WOT hammer down???
new pump???
might just be too much fuel... and injector pulse time might need to be adjusted-----meaning get a tune
Old Jul 11, 2004 | 10:31 PM
When I step on the gas it wants to go down on its nose and it picks up speed again and goes on its nose again. Its annoying! Its like Im losing power
Old Jul 11, 2004 | 10:50 PM
I had a similar problem a couple of months back....
mine ended up being bad o2 sensor.....
maybe same for you..when was the last time you changed the o2's??? tyypically around $60 each...give or take depending on brands and locations...
Old Jul 11, 2004 | 10:52 PM
The O2's are less than a year old. 6 months I think! I am thinkingthat the Stock Injectors and on thier last legs
Old Jul 12, 2004 | 07:56 AM
crainholio's Avatar
...or you burned one of your O2 sensor wiring harnesses...
Old Jul 12, 2004 | 08:21 AM
crainholio's Avatar
O2s play a part in transitioning to WOT, and that's where he is having trouble. If the LTFTs are screwed in the cell he's operating in at the time he stabs the gas pedal, it'll stumble.
If it ran great when he initially nailed it, then fell flat on it's face at higher revs, I'd go with fuel pressure diagnostics.
Old Jul 12, 2004 | 02:42 PM
NicD's Avatar
7 Second Club
Some things to check...
-Throw a fuel pressure gauge on there and watch it on a WOT run. You might see fuel sloshing away from the fuel pickup or maybe the fuel line is cracked.
-use a scanner and watch your factory O2s at WOT. No they are not really accurate at WOT, but if they fluctuate too much you know you probably have a spark/fuel problem.
-check your plugs/wires
-Get tuning.
Old Jul 12, 2004 | 05:00 PM
Going to check the Fuel Pressure. Sure Glad I cut the rear deck so I can get to it. Oh.. NIC you will be the one to Tune MY RIDE,
