Ls1 low oil pressure
Old Apr 17, 2019 | 01:22 AM
erik_g_93's Avatar
Default Ls1 low oil pressure
Hello everyone I recently put an ls1 into my truck and Im getting around 20psi of oil pressure at hot idle Im worried its a bit to low the engine has a ported ls6 oil pump I was wondering if I could Shim the pump or just get a different one? Maybe a high volume Melling?
Cold start: 50-55psi
Hot idle: 20-21psi
WOT: 50-55psi
thanks Im advance
Old Apr 17, 2019 | 01:38 AM
You're fine....
Old Apr 18, 2019 | 04:44 AM
cypris09's Avatar
That's well within spec. Dont worry about it. Here's another thread with the same thing.
https://ls1tech.com/forums/generatio...aring-out.html
Old Apr 18, 2019 | 05:53 PM
NAVYBLUE210's Avatar
From: Coast of San Mateo County Between Pacifica & HMB
That's good, My original LS1 W/151K Miles @ hot Idle 21-22 psi , 6000 RPM WOT 48-50 PSI
with AMSOIL 0W-30 Signature Series.
Old Apr 18, 2019 | 09:14 PM
Polyalphaolefin's Avatar
Not only are you fine with that pressure, that's actually what ideal oil pressure should look like.
Old Apr 18, 2019 | 09:17 PM
Mavn's Avatar
"I MAID THEESE"
100% good. and shimming oil pump does not change Idle Pressure
Old Apr 20, 2019 | 09:59 PM
erik_g_93's Avatar
Thanks for the input guys Ill just keep running it.
Old Apr 20, 2019 | 10:12 PM
You're welcome, and there ya go!
