Pushrod length with LS7 lifters
Old Apr 28, 2019 | 04:10 PM
YungCetaDriver _'s Avatar
Default Pushrod length with LS7 lifters
So I was hearing that you need different length pushrods when upgrading to the LS7 lifters. I have 243 heads going on to a Ls1 and they have been resurfaced. To go along I am upgrading to ls7 lifters. What length pushrods would be the best? Thanks any help is appreciated!
Old Apr 28, 2019 | 04:45 PM
LS7 lifters are the same as those that came before. Just a better lifter. They are stock replacements now anyway. Same pushrods.
Old Apr 28, 2019 | 07:59 PM
Mike Morris's Avatar
I would never run LS7 lifters on any kind of HP build.
Old Apr 28, 2019 | 11:42 PM
So even after resurfacing the heads should the pushrods be the same length? Im a newbie so all help is appreciated!
Old Apr 28, 2019 | 11:59 PM
No. Take the same amount you took from the head from the pushrod length. If it was only a few thousandths, it should be OK.
The best way to know is to actually measure for the length.
Old Apr 29, 2019 | 09:16 AM
Yea I think the best idea is to just measure. I can’t live with knowing it may be the wrong length. Thanks for the help guys
Old May 9, 2019 | 08:53 AM
kinglt-1's Avatar
don't guess...measure!
Old May 9, 2019 | 03:59 PM
Majestic9C1's Avatar
what would you suggest as an alternative
Old May 9, 2019 | 07:00 PM
eseibel67's Avatar
LS7 lifter is slightly longer at rest than LS1 lifter but it also allows for more travel and thats why its a direct replacement. But as mentioned its still best to check length in order to optimize preload.
Old May 10, 2019 | 05:59 AM
Bad346's Avatar
Im finding you have excellent reports on the Johnson 2110s which seem really good but at about 4-5x the cost of a set of Delphi LS7s for me anyway (outside US).
I'm still a bit unsure if anything between that price range, say Comp 850-16s or Morel 5315s really offer anything over the LS7s for the added expense.
For not much more than some of some of the expensive OEM style lifters I can get Morel 5290s or rebranded versions of it which once again I hear mixed opinions on.
I feel like I've turned my car to 7200 for long enough on the factory lifters, surely any of them would do the trick including the LS7s - but a couple of hundred dollars is neither here nor there for a higher quality lifter, especially if it lessens valve train noise which I hate lol.
Old May 10, 2019 | 07:21 AM
mintws6's Avatar
Johnson 2110 are a great product.... they require less preload. I have them in my set up and it is very quiet.
Old May 10, 2019 | 11:27 PM
wannafbody's Avatar
LS7 lifters should be good to 7000 rpm but if you have a really aggressive cam and heavy springs the Johnson would be a better choice.
Old May 11, 2019 | 12:14 PM
patSS/00's Avatar
The ls7 lifter cup is .05 higher than the ls1, this is well documented in some older threads. The preload is about .02 more so that makes up almost half the difference. There's also the gen V lifters sold by BTR and I don't know who else, that as far as I can tell is really the exact LS1 lifter with a different name, but there's almost no info out there about those.
Old May 11, 2019 | 06:21 PM
tech@WS6store's Avatar
LS1Tech Premium Sponsor
The comp 850s are ls7 lifters.
The morel 5315/6504 are a great replacement and you can run at .050/.060 preload
The Johnson are a fully machined lifter hence the price. They use .030 preload so always measure.
For reference about ls7s being used on high hp builds, Leroy ran a 7.80 on ls7 lifters at over 1100hp and considerably less oil pressure than anyone knows. They aren't THAT bad.
Old May 11, 2019 | 08:00 PM
98CayenneT/A's Avatar
Obviously I have way less power but mine have been flawless here.
Aggressive cam, 7100 shift points and absolutley **** pound my car on the street, road course and track.
Also a 4400 stall meaning my car lives between 6400- 7100 rpms
Old May 12, 2019 | 02:15 PM
kinglt-1's Avatar
Johnson 2110.
Old May 13, 2019 | 09:35 AM
93Polo's Avatar
Which cam are you running and what is your intended use for the vehicle?
Old May 14, 2019 | 09:00 PM
my stuff is all stock at the moment but down the road I'd like to get some sort of Stage 2 cam from somewhere.. the car isnt a daily and its usage is for all purpose.. occasional drag strip.. mostly backroads twists and turns and cruising
Old May 15, 2019 | 03:36 PM
93Polo's Avatar
I'd likely do Morel 5315 Drop Ins . Johnson 2110s are nice but the Morels will work well.
Is the 2110 a better lifter? Yes
Is the 2110 worth the extra money? IMO likely not, but read and ask vendors for yourself to make your own call.
If you want to read through a long debate:
https://ls1tech.com/forums/generatio...s-welcome.html
A friend and I work on our cars together. He has a C5 with Morel Drop Ins 243s decked for clean up, FAST92, CamMotion Titan4(?) 226/230, BTR Double Springs and a Straub Trunnion upgrade. He has run multiple track days at Road Atlanta and Atlanta Motorsports Park without problem.
Old May 15, 2019 | 08:55 PM
5315/6504 also can handle .050 to .060 preload. The 2110 need .030. And they dont like thicker oil either. Morels dont care.
