Help reading cam doctor report
What am i missing? Is the cam doctor accounting for some sort of lift loss through the valvetrain?
At 0 lash the measurements check out. Essentially it means nothing except that if you had .01 lash that would be the numbers.
Cliff notes, it adds up and all is good.
As for why it's there, I don't know maybe someone here does. I could take guesses that it may be there for lifter and or push rod deflection to give you a more realistic operating lift. Or it may be there for those running solids with adjustable rockers, or that they just use .01 as a standard for measurement to make things more equal for some sort of reason. But again, at 0 lash the measurements all add up.
If you want to know the exact answer the fastest, you're best route is just call comp (or whoever did the report) and ask them. After you do, let us know, I'm curious.
