Valve stem seals
I'm a fan of the blue Viton valve seals. These need the tool to correctly seat. Here's a typical one they are like ~ $20 typical BTR or Amazon etc. The BTR one may allow more leverage.
The typical valve stem seal doesn't hold up as well as the Viton seals in my experience. Some of the junk seals will side on and off with your fingers. Those seem to start allow oil consumption soon.
That being the case, if these are GM seals, GM provides a measurement in the service manual to ensure the seals are correctly seated. This should avoid excessive tapping into place. I have also found that you can tell by sound when they are seated, they will have a more "solid" sound once bottomed.
