Yella Terra failure
You guys think I should just try to replace this one and hope it was a defect or get a better set of rockers? I’m running a vrx5 cam with tfs215 heads.
I'll run them on AFR 260's @ .632 lift if I wind up getting them.
That's just the conversation we had. When I was thinking about having Darin do my LSA's (and I still might) he wanted me to go with CHE guides and stock rockers.
Since this did not happen to all of the rockers, it tells me Yella Terra has either quality control problems or engineered the product too close to the safety line to save money. Well engineered products engineer in a safety factor of 20% greater than the anticipated loading.
Look at Cranes, Howards, or Crower if you think you should stick with a roller tip.
