Yella Terra failure
YT offers different models of their rockers to suit your valvespring setup. Check out their different series or models and make sure your ordering the right stuff, for what valvespring your running.
Gen1 YT were notorious for breaking. Gen2 was better. Gen3 they got it right. I run the Gen3’s with a big solid roller setup.
Thanks for that information. I looked on Yella Terra’s sight and they do have different models. The ones I was planning to order are p/n yt6645 and they are only rated to 400 lbs. open spring pressure. I have no idea what my open spring pressure is. I never had it checked. I’m running a dual valve spring set-up rated to .650 lift. Any ideas on whether I’d be over that or close. I know I’m going to have to get that figured out before I order a set.
Im running the vengeance racing vrx5 cam. The heads were set up for their vindicator cam which is a bigger cam than the vrx5. I’m guessing I’m right at 400 lbs open spring pressure. Do you know which part number rockers you’re running and what your open spring pressure is on your set-up.
LS7/LSX applications with Mamo Motorsports LS7's
Moderator
Received 1,836 Likes
#32
#34
Go with the newer design YT's and you wont have an issue....I run them on just about every combo I build and design for many good reasons (cathedral, LS3, LS7 etc.)
I have them in stock if you need anything......just PM or shoot me an email and I will get you taken care of
Regards,
Tony
__________________
www.mamomotorsports.com
Tony@MamoMotorsports.com
Anything worth doing is worth doing well. Build it right the first time....its alot cheaper than building it twice!!
#35
I had yella terra's on my TFS 235 heads on a 427. I think they were the 2nd gen but I'm not sure. Ran them from 2009 through the beginning of 2018 without an issue. Had an unrelated issue with the motor.
#36
I went ahead and bought the tsp 1.7 steel roller rocker arms. Now I need to figure out how to adapt the stock Ls1 rocker stands to the trick flow heads and hope I get a good wipe pattern. I read that shimming the stands isn’t recommended. I hope I just get lucky. Maybe someone who’s done this will chime in.
