363ci Stroker kit for L33
The 4 inch stroke 3.80 small bore 363 is possibly the most poorly optimized of all LS engine builds. All of the cost of a stroker with almost none of the benefit. It's hard to imagine a worse bore and stroke set up for NA from what I've seen in the LS world.
In NA bore is far more important than stroke to make good hp. Big bore allows bigger valves, less shrouding and more flow to make mire power. The 4 inch stroke crank is less ideal for forced induction. You better make absolutely sure the correct design piston package is used otherwise that 4 inch crank mini stroker will be an oil guzzling detonation prone pig with ring seal issues.
A good 4 inch bore 3.62 stroke LS2 have more potential and less cost. It will also take boost and rpm better than a 4 inch crank set up.
Punching the L33 out to 3.903 or 3.905 and building a 383 stroker could make for a sweetheart of an engine for that C5. Otherwise sell the L33 and get another motor.
Of course it's your money and project so it's your decision.
Texas speed and Cnc Motorsports is selling Pogie bait ? Just doesn't make sense. Obviously the 4.00" bore with 4.00" stroke will hava a better ratio than a 3.80" bore and 4.00" stroke.
If I go 3.800" now, then later on I can go 3.898" then after that I can go to a 3.905" bore. It's called conserving the block for a later use. Taking all the material out of the bore of the block all in one go is like you saying you wanna be a strong *** man
but live a short *** life.
So that little difference in size will cause it to use more oil ?
Questions are great! Ignoring good advice in the answers is foolhardy.
I bet if you ask TSP or CNC Motorsports which is better that small 3.8 bore 363 or a 3.903 bore 383 for NA hp & torque the and isn't going to be the 363. I wouldn't be surprised if a 4 inch + bore 402 or 408 is suggested as a better overall set up than any 3.8 or 3.9 bore engine. Of course if you really want a 363 I'm sure either will happily sell you a 363 set up
The name of the game is help find something that makes the customer happy and sell it to them...I have two strokers a 383 and a 416 up and running and a 408 slow coming together just speaking from experience. I'd honestly hesitant to do a 383 because it cost nearly the same as a 402/408. I have researched LS engines since 1998 and a 363 is a horrible set up for the cost involved. Buy a stock bottom end LS2 short block for like $4,000 from Thompson Motorsports or TSP. It will have more potential or the same with upgraded pistons.
If you look at the bigger picture it would be worth it to save a little longer and go with a larger stock bore aluminum piece. You can get a new LS2 block for $1600 shipped to your door, I'm not sure what condition your 5.3 is in now but if it's good running engine it should be worth a several hundred dollars making the new block much cheaper and it will probably need less prep at the machine shop than your current block so you'll save some there also.
As far as I know they were only offered in a select few 4x4 trucks for only a few years. The rarity Of the L33 will continue to go up, Racers want them because they make Awesome Turbo Builds, Country Boys want the whole Truck so they can go stick it in the mud and tear it up, or flood it out. In 20 years you'll be finding engines from 2019 in the junkyard. You wont be finding any LS1's or L33's and if you do it will be a miracle and a blessing. Lol
