Pushrod lengh
Old May 27, 2019 | 10:57 AM
syncmaster710n14's Avatar
Default Pushrod lengh
Hi guys, just want your thoughts on this,
I have milled the heads on my LQ4 by 0.040''. Standard LS pushrods are 7.400'' so you would think i need 7.360'' pushrods to compensate, but I have just checked with a pushrod length checker and I am only getting to 7.225 with no lash. So even with a preload of 0.050'' that is only 7.275 which seems to short?
Anyone have any ideas how this works?
Thanks
Sam
Old May 27, 2019 | 01:25 PM
Are you mocking it up with head gasket in place?
Old May 27, 2019 | 01:27 PM
Heads are on with gaskets and torqued up ready to go.
Old May 27, 2019 | 01:30 PM
What headgasket did you use? Was block decked?
Old May 27, 2019 | 11:35 PM
Standard Block and gaskets (AC Delco I think)
Old May 28, 2019 | 12:57 AM
1FastBrick's Avatar
I just had a set of heads milled .025 . I installed them with OEM GM gaskets and with some 7.350 pushrods I already have, I have too much preload.
FWIW the OEM pushrods are not 7.400 they are actually in the 7.38 range.
Old May 28, 2019 | 03:46 AM
That's interesting, I have been looking through the forums and some people are running preload at over 0.100''! Thinking I might go for 7.300'' pushrods that should give me 0.075'' preload.
Thanks for your response
Sam
Old May 28, 2019 | 04:55 AM
The head gaskets I got are ACDelco 12610046 6.0/6.2
Old May 28, 2019 | 12:43 PM
What length pushrods do you think you are going to need?
Old May 28, 2019 | 01:44 PM
1FastBrick's Avatar
I suspect 7.325 to achieve proper pre load. I already had 2 spare sets of pushrods from other projects laying around.
With 7.375 I achieved 1 3/4 full turns past 0 preload Torqued to 22 FT LBS
With 7.350 I achieved 1 1/2 full turns past 0 preload Torqued to 22 FT LBS
I did not have my adjustable pushrod length checker with me. I need to pick it up and Verify
1 Full turn is .079 Pre load.
So 1 1/2 full turn Should be roughly .0118 Pre load.
I dont want to post a non sponser site since they sell parts But I found a really good tech article on lifter preload
Here is the video they made showing actual lifter preload as you turn the factory bolt 1 full revolution.
Old May 28, 2019 | 02:19 PM
https://www.youtube.com/watch?v=pB40wxeR-NM
Thanks bud, that video explained it really well, I'll let you know how I get on.
Thanks again.
Sam
