Compression ratio question
Old Jun 9, 2019 | 10:27 AM
fastlt1's Avatar
Default Compression ratio question
If you shave 30 off stock 5.3 heads 706 862. Install on 99 stock ls1. What would compression ratio be?
Old Jun 9, 2019 | 10:55 AM
Check out Summit's Compression Calculator on their site. It will tell you as long as you know bore, stroke, chamber volume, etc.
