6.100 Rods with stock crank & block
Hi! Can i use 6.100" long connecting rods, with stock crank, and this JE Pistons? Rod length difference compared to stock is only 2 thousands. Seller description says "This piston can also be used with aftermarket 6.100" length rods" Do i have to consider some details if using longer rods? Extra length is visible in piston deck height, and that rises compression, witch is good when i am aiming to 11 ratio. Here is the rods that i have been looking for. Can you tell me some points if i use H-beam style forged rods?
Non-Sponsor Soliciting Policy
