Anyone install both Oil Press & Oil Temp Gauges?
Old 03-21-2003, 05:00 PM
Brownie's Avatar
Default Anyone install both Oil Press & Oil Temp Gauges?
I have autometer gauges for both oil temp and oil pressure and want to install them both on my 99 Ram Air. Problem is the only place I know to install them is just above the oil filter. Drill and tap it then install the sending unit.
Problem is I want to install both. I like oil temp for warm up (especially springs) and roadcourse stuff. I think the oil pressure is the most important.
Really want to install both accurately.
Any help would be greatly appreciated.
Thanks,
Mike
Old 03-22-2003, 11:06 PM
ibjamin's Avatar
Default Re: Anyone install both Oil Press & Oil Temp Gauges?
TTT. I'm also interested.
Old 03-22-2003, 11:27 PM
xssive's Avatar
No problem. Just tap the piece above the filter and use regular plumbing fittings to make a T off of that fitting for both of your senders.... There is plenty of room down there
Old 03-23-2003, 03:34 PM
Brownie's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by xssive:
<strong> No problem. Just tap the piece above the filter and use regular plumbing fittings to make a T off of that fitting for both of your senders.... There is plenty of room down there </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Thanks! I thought about that, do you think it will affect the accuracy of either gauge??
Old 03-25-2003, 06:57 AM
Brownie's Avatar
Anyone??
Old 03-26-2003, 10:06 PM
Racehead's Avatar
I drilled my oil pan below the low oil sending unit to mount my oil temp gauge.
