4.8 ls6 top end hp
Something as simple as your doing you should defiantly be able to get away with a mail order tune. Once again you might gain a little more with a dyno tune but.... probably not worth it.
I understand what your trying to do, but there is NO WAY I would run the stock cam in that thing.
The best cam for a 4.8 N/A from 0-4000rpm is the stock one period. Even the gm 1721 aka the 01 and up 5.7-6.0 cam will lose a noticeable amount of tourqe at 2000 rpm over the 0967 (stock 4.8-5.3) camshaft, though the little 1721 will still carry hard all the way to 7200 with an LS6 intake and stock F-body manifolds in my testing.
The 0965 (98-00 LS1 F-body) camshaft has roughly the same IVC @ 0.050 as the 02-04 ls6 cam and will kill cranking compression and power under 5k in the 4.8 though it will pull past 7200 with those cheap LS6 springs.
I'm currently running an older comp cams grind 212/218-115+0 and it is very mild however the power is significantly better than stock at higher RPM and no worse on the bottom than the 1721 (5psi more cranking compression in my testing)
After researching cam swaps I believe I can complete the task along with changing valve springs& seals.
So are you saying it will be slow either tuned or not tuned?
Im using the 4.8 vs the 5.3 because I know the 4.8 is a good working engine , unsure of the 5.3 although both turn over, plus I can re use the crank in 5.3 for 5.7 build.
The heads on 4.8 was leaking coolant somewhere but was not visible on the ground original owner stated so thats why I'm using the ls4 243 heads and complete ls6 intake (intake,fuel rail, injectors)I already have.
The 243 heads were pressure tested and check out good. The other 706 heads on the 5.3 Im not sure about.
So. It seems I will
break engine down to shortblock
Change cam to whatever Is decided
change valve springs and seals on 243 heads(and at least mill them to yield a 10.1 compression)
Ls6 intake for clearance issues
Install longtubes
Use the stock 4.8 4l60e and converter for now (later get a race ready 4l65-e from Dr. Steve transmissions or a sponsors 4l80e built to have for 5.7 iron ls1 )
Will get Brandon to reflash for upgrades and find someone to street tune last
The increased intake valve size of the 243 head on the 4.8 in a way acts like a bigger intake lobe on a cam so you wouldn't need much cam, but at 64cc you'll need to mill enough for at least 3cc off just to get to stock compression of 9.5:1 with the 706 heads @61cc. You'll need to mill a lot to get to 10:1 with the 243 heads so I still stand by my recommendation that you use slightly milled 862/706 heads on a budget 4.8 build and save the coveted 243 for your iron 5.7.
I'm currently running a 212/218 115+0 in my otherwise stock 9.5:1 compression 706 headed 4.8 with ls6 intake and it's probably too big for a 4.8 with the stock converter I think and it really likes being shifted at 7k.
For those who dont know, this is going into a 86 Camaro. Its the only reason for the ls6 intake for clearance, and the heads on the 4.8 were leaking(castec) but I have a set of pressure tested good 243 heads that I took of a ls4 in the junkyard... (talk about pain in the ***) I paid $100 for them but after a few choice words, scratches and bruises I got them off... I worked to get those heads. Will never again take heads off a fwd car if I dont have to!
Im about to just scrap the whole thing and just wait for the 5.7 build. My camaro has been sitting for awile and I just wanted to put something in it to at least get motivated to start getting interior, suspension, etc.. going..
@kingtal0n are you trying to tell me something with that cam??
cam: 'sloppy stage-1' ideal for daily drivers
application is: 4.8/5.3L turbo 500-700rwhp using a factory engine
goal is: Use the lowest lift, slowest ramp camshaft available to max valvetrain life, also keeping economy and drivability
The cam is ideal because it will be very gentle on the factory lifters, pushrods, guides,valve hardware. This will minimize wear/tear and max valvetrain longevity.
Very slow opening rate maintains stability at high rpm.
And perhaps most importantly it has enough duration to lope at idle and make the torque/power a stock head engine is capable of.
No reason to go larger unless the goal is 700-1000rwhp in which case I would step up to the next 'mild' camshaft, sloppy stage-2
I'm surprised it wasn't mentioned way earlier. Heres a random much older 4.8L thread
https://ls1tech.com/forums/forced-in...bo-recipe.html
heres his recent dyno of 4.8L at 700rwhp using the .585/.585 cam (largest version on 1218PAC springs)
Hes going for 850-950rwhp probably spinning 6500-7000~ so the larger cam makes sense. For my (and most daily drivers) purposes however I like to keep rpms below 6k or just around 6k for longevity. So the smaller cam makes more sense.
