Problems Bad or Real Bad??
Old Jul 12, 2004 | 11:12 PM
SSLS1's Avatar
Default somone help!! Problems Bad or Real Bad??
ok well i decided to go start my car and it started made some knocking noises for 2 seconds and died, wouldnt start back. checked oil, level was real high?? checked radiator, no water. pulled drain plug and i found the water and the oil. is it possibly a head gasket or cracked head or somthing else??? it ran fine saturday(last time i drove it since allen nelson custom tune) what could have caused this to happen?? Info would be helpfull, i guess i will pull the heads of tonight,
Old Jul 12, 2004 | 11:46 PM
CaptUSA's Avatar
Wow, that truely blows. I just had a head gasket go out on me, but my car didn't die like yours did. I was able to actually drive it down the the mechanic. That's some bad feelings comming out of that story. Good Luck man.
Old Jul 13, 2004 | 12:59 AM
SSLS1's Avatar
could it possibly have spun a rod bearing to make the knocking noise and thats why it woulnd start back?
Old Jul 13, 2004 | 01:45 AM
MelloYellow's Avatar
Last time mine did that, I had a slow headgasket leak.
Filled up a cylinder with water overnight and it couldn't crank over.
Don't crank anymore or you could bend a rod or more likely just damage a rod bearing.
Old Jul 13, 2004 | 01:59 AM
SSactionLs1's Avatar
water doesnt compress... If water is in your engine then you may have pretty much snapped your internals. (Been there done that)
Old Jul 13, 2004 | 04:37 AM
SSLS1's Avatar
ok well i pulled my drivers side back spark( #8??) plug out and it was beat down into the spark plug??? im guessing this problem is real bad, i have the heads ready to come off as soon as i cut the headers loose from the y-pipe
Old Jul 13, 2004 | 01:03 PM
SSLS1's Avatar
anyone ever had this happen before??
Old Jul 13, 2004 | 03:36 PM
SSLS1's Avatar
ok well i got the heads off, OUCH, #8 cyl is beat to hell, the head of the valve broke off and put a whole through the head and filled the cyl up with water. should i check the bottom end out for more damage?? anyways i called the guys and patriot and so far the customer service seems to be great, they offered to fix the head for me, so that will save a little money,
Old Jul 13, 2004 | 03:52 PM
NataSS Inc's Avatar
Sounds like you need to do a complete tear down. there might be more damage in there.
Old Jul 14, 2004 | 12:52 AM
Did the spring break on that valve? What caused the valve to bend?
Old Jul 14, 2004 | 02:22 AM
SSLS1's Avatar
The Valve isnt bent, its broken! the spring is fine, this was the first issue of patriot heads with the bad valves i have been hearing about i guess, anyways patriot is supposed to be fixxing the problem for me, great customer service so far
Old Jul 15, 2004 | 03:36 AM
SSLS1's Avatar
well i got to lokking at the broken piston and i pulled a piece out of the middle and i stuck my finger through to see if anything under it was damaged, well i didnt feel anything so i tried to pull on the piston, it came right on out and crumbled into a glob or broken metal, the rod broke off it at the wrist pin, i havent found the rod yet, guess its probly in the block!!
Old Jul 15, 2004 | 03:43 AM
dragonZ28's Avatar
Dude, there is bound to be more damage internally. Pull the pan, and check the rods and crank journals for scarring. How does a valve just break? What kind of springs are you running to pull a valve up with enough force to snap it? I have never heard of this before.
Old Jul 15, 2004 | 07:02 AM
DANSLS1GTO's Avatar
Was there any noise from inside before this? Sounds an aweful lot like you spun a rod bearing - but you typically will hear the signs of that coming.
Dan
Old Jul 15, 2004 | 04:36 PM
APeteSS's Avatar
Can we have some pictures please?
Old Jul 15, 2004 | 05:10 PM
1fastWS6's Avatar
The valve probably broke after the rod let loose and smashed into it. Just a guess.
Old Jul 15, 2004 | 11:23 PM
terrygs31's Avatar
Sounds like Coolent washed the bearings.
Old Jul 15, 2004 | 11:57 PM
SSLS1's Avatar
i will get some pics up here in a bit, i was running the patriot dual gold springs. dont exactly know what happend,
