Low Oil Pressure in 5.3 :/
Old 07-23-2019, 10:59 AM
fuckusernames's Avatar
Question Low Oil Pressure in 5.3 :/
I have a sn95 that i LS swapped here recently and first couple start up were fine as far as oil pressure goes: 30 psi idle and 50-60 stepping on it.
All of a sudden it dropped down to 20 psi idle and maybe 30 steppin on it. Took the oil filter to a buddy who has a performance shop who cut it open and there
was some metal bits in it but not many. He even said it didnt look too bad.
It was running 10w-30 then i switched to 20-50 after pressure drop. No change in pressure that i noticed.
Pressure is being measure by mechanical gauge so i took the line off the back and put a catch bucket next to it and cranked the engine. Oil came out in spurts. Not a steady stream
some for 3 seconds, stopped for 2 seconds, back on for 3 seconds and thats how it stayed.
Havent pulled screen from under pressure gauge port yet but i wanted to see some second opinion on whether this is air getting past the pickup tube o-ring or the spurty oil being an
actual symptom of worn bearing.
Other than those 2 things i cant think of anything else that would give me low oil pressure like this.
Thanks in advance for the replies any opinion matters at this point.
Old 07-23-2019, 11:37 AM
Ls7colorado's Avatar
Id check pickup O ring first
BUT, there was metal in the filter so??
Old 07-23-2019, 05:22 PM
"I MAID THEESE"
Mavn's Avatar
if there was metal in the oil something is hurt.
-Mavn
The following users liked this post:
Ls7colorado (07-23-2019)
