Sudden drop in oil pressure @ idle
Old Aug 6, 2019 | 07:39 PM
War Prayer's Avatar
Default Sudden drop in oil pressure @ idle
Greetings, and thanks in advance.
Car is a heads/cam build a few years old. Forged bottom end, melling high volume oil pump. 5k on build and 65k on the car.
The following readings are from the stock gauge:
Ever since I have owned the car it idled at around 40psi hot and shot up to 60 even cruising at 2-3k. I always thought this was a little high but I never let it bother me.
Today I fired the car up and after letting it warm up I noticed the pressure at hot idle was 20-25psi. Hits ~40 cruising and 55-60 at WOT all the way up to 6k. This doesn't seem abnormal to me, the car pulls hard with no weird noises or anything. Normal amount of oil consumption it's always had and same little bit of blue smoke at WOT the car has always had.
Is there any reason to worry about this given that it's changed so drastically? The oil pressure still responds to throttle input like you'd expect it to and never drops below 20, it seems like basically what a stock LS1 reads. Am I reading too much into this with regard to trusting the stock gauge and sending unit? I come from the SBC world but I am not super familiar with these engines and I didn't build this car.
Old Aug 6, 2019 | 07:55 PM
I wonder if the relief piston in the oil pump might be stuck where the bypass port is SLIGHTLY uncovered, thereby letting a little pressure bleed off.
It's the only thing I can think of that can happen suddenly.
Old Aug 7, 2019 | 07:25 AM
psicko's Avatar
Are you using the same oil you always have? I would cut the filter open and make sure there isn't any bearing material in there.
Old Aug 7, 2019 | 07:44 AM
War Prayer's Avatar
Oil pump and sending unit failures seem to be my best hope right now. After some searching it seems more common than I thought with the melling pumps.
Same oil and filter I always have. I plan on draining the oil today to see how it looks, but the car is running fine.
Old Aug 7, 2019 | 01:23 PM
War Prayer's Avatar
So I drained the oil and cut the filter and found nothing significant, however the car is suddenly smoking a ton through the exhaust. Maybe valve seals?
