5.3 with 243 heads
Old Aug 7, 2019 | 03:17 PM
John David Long's Avatar
Default 5.3 with 243 heads
Hey guys. I have a c10 with a 5.3 in it. It’s got a tsp 224/224 600/600 110lsa cam. I have my hands on a set of nice 243 heads. My 5.3 has dish pistons in it and I was just wonder how much I can mill them down without hitting the valve and still running pump gas. I want the most compression on pump gas I can get. This is a NA build but might put a small shot on it one day.
Old Aug 7, 2019 | 03:38 PM
LilJayV10's Avatar
check PTV and mill according.
Old Aug 7, 2019 | 03:49 PM
How would I check the ptv
Old Aug 7, 2019 | 05:19 PM
Mavn's Avatar
"I MAID THEESE"
www.google.com
How to check PTV.
Old Aug 7, 2019 | 05:33 PM
JoeNova's Avatar
Restricted User
4.8 flat tops would gain you more than 243 heads.
Old Aug 8, 2019 | 02:56 PM
Default 5.3
I want to get more compression without taking the motor out or taking the bottom end apart
Old Aug 8, 2019 | 05:16 PM
LilJayV10's Avatar
Originally Posted by john david long
i want to get more compression without taking the motor out or taking the bottom end apart
then measure your ptv now and figure out how much you have.
Then mill accordingly.
same thing i said before.
Old Aug 9, 2019 | 09:37 PM
Kawabuggy's Avatar
862 heads? Smaller combustion chamber=higher compression. Or thinner head gaskets.. A .040" or .041" head gasket will also start you in the right direction. Or, pair the thin head gaskets with the 862 heads... Definitely a good bump in compression.
Old Aug 10, 2019 | 08:24 PM
SoCalDave's Avatar
Run the 5.3 with the 243 heads as they are. You should make good power with those heads and that cam. Sometimes it's better to get your project up and running and then circle back to get other parts installed.
Old Aug 10, 2019 | 09:00 PM
Utinator's Avatar
You would need 60cc chambers and a .030" thick head gasket to get 10:1 compression with those dished pistons. That's a lot of work for a small bump in compression. I'm not sure you can mill 243s that far down anyway.
Your best bet is to pull the pistons and put some flat tops in there. Either that or just put the stock 706/862 heads back on there and boost it. Either way, I don't recommend running stock 243s with those dished pistons. That would be about a 9.1:1 compression ratio with stock head gaskets.
Old Aug 11, 2019 | 12:28 AM
SoCalDave's Avatar
The difference in heads that flow well like 243 heads with a .600 lift cam over the lowly 862 heads is so big that a drop in compression is acceptable. If you've ever bolted on a set of good heads you'd know to never go back.
Old Aug 11, 2019 | 05:57 AM
cookseyb's Avatar
Send the 862's to Texas speed and get their CNC job with 2.02 intake valves and 1.57 exhaust ( same as 243-799) they will give more compression and flow as good as the 243's (or better) . I did mine along with a .030 mill job and they came out great!!
Old Aug 11, 2019 | 08:25 PM
LilJayV10's Avatar
great info in this thread.
Old Aug 11, 2019 | 08:50 PM
98CayenneT/A's Avatar
https://ls1tech.com/forums/generatio...ve-method.html
Old Aug 13, 2019 | 08:18 AM
L33's Avatar
L33
I think milling beyon .030 will run you into intake manifold angle issues at the gasket mating surface.
My advice: Bite the bullet and get flat tops in there and then put those heads on. (Look at the factory L33 5.3 they ran 799(243) heads but ran flat top pistons).
Old Aug 13, 2019 | 09:09 AM
JoeNova's Avatar
Restricted User
The intake bolts are vertical, not perpendicular to the head like old school engines. You have to mill like .120"+ before you start having issues.
Old Aug 13, 2019 | 06:29 PM
Utinator's Avatar
True, but the heads are angled. At some point you will have mating issues. I have no idea what that point is, but it is something to keep in mind. I took my heads down .030", and have no issues. FWIW....
Old Aug 14, 2019 | 01:17 PM
Lsbmer's Avatar
You sure about that? Been proven more than once
Old Aug 14, 2019 | 02:47 PM
Lsbmer's Avatar
There is more to heads than cfm. Alot more.
Port shape can make a dramatic difference even if cfm is the same. Air quality can be worth more than quantity.
Velocity around the valve . Goes on and on.
Here some molds I made . Sometimes a pic is worth more than words.
Besides the port shape and valve size
being alot different between the 2 heads. The squish pad and squish velocity is also different between the 2 heads. clay under the valve is a mold of that heads combustion chamber. Both heads have correct valve size in pics.
Old Aug 14, 2019 | 06:59 PM
SoCalDave's Avatar
I've seen that article. One thing I've learned is that magazine numbers are usually skewed to reach a predeterminded conclusion. Youtube can give a better real-world idea of the performance of the different castings and 243s and 799s are the castings that the LS community uses on their rides. I wouldn't use anything less than at least the stock 241s on my '01 Camaro.
