Cam selection
Old Aug 22, 2019 | 09:18 PM
wannafbody's Avatar
I have the BTR stage 2. I also have a M6. Maybe it works better in a manual than an autotragic. I initially had a couple issues but replacing the IAC and adjusting the throttle cable mostly cured that. I get the occasional buck crawling through a cruise lane or parking lot.
Old Aug 23, 2019 | 12:37 AM
Mavn's Avatar
"I MAID THEESE"
Originally Posted by Kfxguy
O, something else. There’s no sewing machine noise at idle and it made 459rwhp In Mavn’s car. Stock bottom end 5.7 with this cam, heads and a fast intake and full length headers.
...and went 11.0s full weight 3600 lbs !
Old Aug 23, 2019 | 06:40 AM
Tuskyz28's Avatar
^^^^ impressive!!
Old Aug 23, 2019 | 07:18 AM
Kfxguy's Avatar
And there’s that. Lol. The most important thing!
Old Aug 23, 2019 | 07:25 AM
Darth_V8r's Avatar
Moderator
Originally Posted by legen-waitforit-dary
I just had the TSP 228/232 112LSA installed and tuned along with TFS220 as cast heads, 25%UD pulley, 1⅞ long tubes and a magnaflow cat back it made 440/379 on a very humid 97* day and I love it. I think the car drives better now than when it was completely stock. There was some bucking when cruising in 6th around the city so I just used 5th instead. I can't recommend this cam enough for anyone looking for something easy to drive while still being a huge improvement over stock. I have the rev limiter set at 6500 right now and it is still making power up top and my tuner says that it could be around 460-465 with better air. He was actually impressed how well everything worked together because he thought it would be around 420 maybe less. I'm still on stock gears but I'm definitely thinking about making the jump to 4.10s or 4.30s just to get into the powerband sooner, you can definitely notice the 3.42s aren't making the most out of my setup.
I recommend 4.30. I ran with 4.11 and was underwhelmed. Should not have been that big a difference but it was.
Also recommend raising your limiter to 7200. Your limiter is right on your power peak. Raise limiter to 7200, shift points to 6800, car will go more fasterer.
Old Aug 23, 2019 | 09:49 AM
trilkb's Avatar
Dont forget a rear end that could take a launch too.
I thought that car had some other secrets, like not stock heads. Maybe Ive forgotten.
Old Aug 24, 2019 | 09:38 AM
Mavn's Avatar
"I MAID THEESE"
Stock 706 heads ported .
4l60e
10 bolt .
No secrets
Old Aug 24, 2019 | 10:38 AM
tech@WS6store's Avatar
LS1Tech Premium Sponsor
Originally Posted by HATEDBIRD
Trying to decide what cam to go with so I’m gonna ask some fbody guys who mostly daily drive(everyone has a different definition I know)My last build was a big cam th400 high stall setup so I’m prepared to loose 6th gear on the interstate and all that good stuff.
Heres what I got
2000 SS
150k
Dorman LS2 4 bolt intake
92 mm TB
42 lb injectors
sniper fuel rails
M6
3:73 gears
heads will get a valve job and minor port work if any,springs changed
LS7 lifters and cups
Texas speed cam kit
i don’t want to change the rockers
i wanted to go with magic stick 4
lee at Texas speed really pushed the torquer V2 at 112 LSA instead
Well what’s the word on cam selection for this beast?
and if someone knows,will I need a regulator will the sniper fuel rails and what do I do about the rerun line to the tank?
Thanks in advance.
My last LS build was in 09 so be easy one me lol
Use the 224/228 112lsa from tsp. No need to go so big for what you want. Great sound great power. Less lift isnt worth it so keep it high and have fun!
Old Aug 24, 2019 | 06:08 PM
NAVYBLUE210's Avatar
From: Coast of San Mateo County Between Pacifica & HMB
Agreed!
LOL
Old Aug 25, 2019 | 12:08 PM
TXZ28LS1's Avatar
TSP 233/239 112.. Drove perfectly fine. No issues at all.
Old Aug 25, 2019 | 01:02 PM
legen-waitforit-dary's Avatar
I am glad to see that your recommend the 4.30s too, the day I picked the car up I knew the 3.42 weren't going to stay in the car for very long and after about 30 minutes I was telling my buddies I was going to be putting 4.30 gear set in it soon. It should be a ton of fun and the limiter is definitely going up once I get some sticky tires on the rear as well since I upgraded the entire top end to spin higher when I had it all installed.
Old Aug 25, 2019 | 01:15 PM
  #32
Bob570's Avatar
I have a Torquer V2, it only bucks around 900-1000 rpm after it's warmed up, I have stock 3.42s with an M6, so with 3.73s it should buck and surge even less.
