valve spring life span
Old Aug 20, 2019 | 08:55 PM
c4boom's Avatar
Default valve spring life span
I was just wondering what pepole have seen for valve spring life span with cams in the 235 239 and 0.623 0.626 lift range. Also what tends to hapen when a spring brakes with pac duel springs.
Old Aug 20, 2019 | 10:33 PM
Ls7colorado's Avatar
if a spring breaks you will normally trash the head and that piston/cylinder, possibly the entire engine
Old Aug 20, 2019 | 10:59 PM
wannafbody's Avatar
Dual springs offer more protection. Some people check them at about 20K but someone here ran a set for 50K without issue.
Old Aug 20, 2019 | 11:06 PM
c4boom's Avatar
I have 34k on a set of pac 1206x springs at the moment. Starting to think about swaping them.
Old Aug 21, 2019 | 02:06 AM
pdxmotorhead's Avatar
In road racing, with a GT level engine, the springs get swapped about twice a season at the Amateur level..
They don't typically hold their pressure uniformly much longer than that. that's about 8 track weekends.
On a sprint car the springs get checked about every 8 to 10 race weekends. (406 small block running north of 9500.. )
Old Aug 22, 2019 | 12:16 AM
c4boom's Avatar
I know more rpm and more lift equal shorter life.Has any one had a spring fail on them just due to use?
Old Aug 22, 2019 | 10:26 AM
wannafbody's Avatar
Some Comp 918 single springs have failed.
Old Aug 22, 2019 | 11:22 AM
A LOT of Comp 918 single springs have failed.
Fixed it for ya.....
