Let’s guess what is broken - updated
Old Aug 28, 2019 | 06:07 PM
j-mart32's Avatar
Default Let’s guess what is broken - updated
Was getting the car tuned and everything was “going well”. Tuner was going around the block cleaning up the cruising AFR and this noise came in. He shut it down and rolled into driveway.
Can’t pull the valve covers till Later tonight after work
Old Aug 28, 2019 | 06:13 PM
Dren's Avatar
Intrigued..
Old Aug 28, 2019 | 06:17 PM
LilJayV10's Avatar
Left rear taillight is out
Old Aug 28, 2019 | 06:22 PM
j-mart32's Avatar
Old Aug 28, 2019 | 06:24 PM
j-mart32's Avatar
Video posted. Sorry on delay, new to vids and doing this via phone
Old Aug 28, 2019 | 06:32 PM
s30.hybrid's Avatar
Sounds like a valve event... something top end. Maybe a broken spring or rocker arm.
Old Aug 28, 2019 | 06:37 PM
98CayenneT/A's Avatar
Im going rocker arm came loose.
Agreed. Sounds like it’s half the speed of the engine so hopefully it’s top end.
Old Aug 28, 2019 | 06:51 PM
j-mart32's Avatar
I’m hoping top end and something stupid. The noise is a hollow sound and rhythm is weird for sure. It had been making good pulls with no issues and then did this at 17% throttle 🤦🏻dum♂️
Old Aug 28, 2019 | 06:55 PM
j-mart32's Avatar
I should include that it’s a decent top end. Jesel rockers, pac 1208x springs, motel 5850 lifters. Hoping rocker is loose like someone mentioned
Old Aug 28, 2019 | 09:50 PM
j-mart32's Avatar
Another question for when I get home to check it out some. If the top end looks ok, I’m gunna disconnect the coils/ injectors and turn it over. How much oil pressure should I see when cranking the engine over?
Old Aug 28, 2019 | 10:33 PM
LLLosingit's Avatar
With the spark plugs out I usually see 35-50 on used engines.
Old Aug 28, 2019 | 11:05 PM
j-mart32's Avatar
How about with plugs in, coils disconnected ?
headed home now to start checking stuff. Starting at flex plate/ bolts
Old Aug 29, 2019 | 12:59 AM
j-mart32's Avatar
Old Aug 29, 2019 | 07:46 AM
Mavn's Avatar
"I MAID THEESE"
This is why stock rockers >
Old Aug 29, 2019 | 08:28 AM
ddnspider's Avatar
We don't need no mountain lift and rawkers....stock FTW.
Old Aug 29, 2019 | 08:44 AM
j-mart32's Avatar
Old Aug 29, 2019 | 09:48 AM
KCS's Avatar
KCS
Moderator
Originally Posted by j-mart32
Thats pretty crazy. I wonder how that could have happened.
Old Aug 29, 2019 | 10:12 AM
j-mart32's Avatar
You and me both. Trashed three of them. Shaft was snapped and so was the top of the bolts so they are still in there.
Hoping the damage is limited to here though, and the cam is OK
Old Aug 29, 2019 | 10:30 AM
Maybe Jesel had a bad day when those were made...
