LM7 build first time
Old Oct 7, 2019 | 06:52 AM
Ls7colorado's Avatar
If your going to use a shorty header just see if you can find some stock manifolds that will fit.
The plug access with some of those shorty can be a PAIN and I have seen several burn plug wires. They also dont gain much power if any over stock cast manifolds.
Old Oct 7, 2019 | 09:41 AM
Impala1965's Avatar
I think there Will be clearence issues with stock manifolds.
Btw whys there two holes in the cam bearing but only one in the block?
Old Oct 19, 2019 | 04:14 PM
Impala1965's Avatar
So the engines coming together, shouldnt there be a gasket here? I cant find any in the set
Old Oct 19, 2019 | 05:44 PM
No gasket. It’s a machined surface mated to the oil pumps machined surface. You could smear an ultra tiny dab of ultra grey around it, but it’s not needed.
Old Oct 19, 2019 | 05:55 PM
JakeFusion's Avatar
Super Hulk Smash
It just installs... if you are using a double row and have the spacers, I'd recommend spraying the spacers with copper spray before installing to ensure no leak.
Old Nov 10, 2019 | 12:34 PM
Impala1965's Avatar
So I've got the heads on and everthing. Now I need to flash the ECM. Is it something I could do myself or do I need to send it to someone?
